0) Buy one of these to save the hastle after buying an HxC
http://www.ebay.co.uk/itm/121373461801? ... 1497.l2649
1) Make sure that the red stripe is on the right side when coming out of the Amstrad and on left side when going into the HxC SD SLIM
2) Make sure both switch 1 and switch 2 are both ON and all the rest are off
3) Make subdirectories for games on the SD card, 8GB is recommended ( Label them A-Z ) with games A in A, B in B and they have all been converted to *.HFE
4) Download the manager here and extract to SD card
http://www.norecess.net/hxc-floppy-emul ... nager.html
5) Load the SDCard HxC Floppy Emulator and set "Enable auto boot mode" and "Force Loading Autoboot.HFE at power up " - SAVE CONFIG FILE
6) Place SDcard in, boot the Amstrad and everything else :p Then do Run"HXC
7) Homebrew games or music can be run after slotted with the command Run"Disc
