Two HxC in same Amiga
CBMFreak
Post by CBMFreak »
I have been thinking about buying an extra HxC and use it together with my existing HxC in an Amiga 1200.
In this case the HxC F in a white case. I already have a HxC slim.
My question is this:
If I use a pc twisted floppy cable to connect both HxC to the same amiga
and then jump the HxC F as DF0 + DF1 and the slim HxC as DF2 and DF3
will that then work allowing me to have 4 emulated floppy drives on a single computer?
(I plan to use the indexed mode on the cards in the HxC slim so that I can change floppy images in the slim without needing any UI)
Re: Two HxC in same Amiga
CBMFreak wrote:I have been thinking about buying an extra HxC and use it together with my existing HxC in an Amiga 1200.
Yes this is possible but you need add two wires connected from the external floppy port. DF2 & DF3 select lines are only present on the external port.
CBMFreak
Post by CBMFreak »
Ok :)
