Linux Version of SLIM HxC Floppy Emulator Software
ldkraemer
Post by ldkraemer »
I'd like to request a copy of the Linux Version of HxC_Floppy_Emulator_Software for the SLIM.
The file: HxC_Floppy_Emulator_Software_User_Manual_ENG.pdf states the following:
HxC Floppy Emulator Software User Manual
Rev.1.0 - 05/13/2013
This tool can be downloaded there :
https://hxc2001.com/download/floppy_driv ... r_soft.zip
This software is available on Windows, MacOS X (x86) and Linux machines.
This Step by Step guide intend to describe some basic tasks.
The Linux version is not included in the HxCFloppyEmulator_soft.zip file.
How do I Request a current Linux Version?
Thanks.
Larry
Re: Linux Version of SLIM HxC Floppy Emulator Software
Just get the whole svn tree :
http://sourceforge.net/p/hxcfloppyemu/code/HEAD/tree/
and make the software.
ldkraemer
Post by ldkraemer »
Jeff,
Thanks for the tip on getting the svn code. I've got it compiled on Debian 7.x and I'm testing a few *.td0 files.
I've tried this command and it appears to function properly:
./hxcfe -finput:ampro.td0 -infos
larry@debian:~/Downloads/HxC/slim/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:ampro.td0 -infos
HxC Floppy Emulator : Floppy image file converter
Copyright (C) 2006-2014 Jean-Francois DEL NERO
under certain conditions;
libhxcfe version : 2.4.5.1
Input file : ampro.td0
- File informations -
File: ampro.td0
Checking ampro.td0
File loader found : TELEDISK_TD0 (TELEDISK TD0 Loader)
Loading ampro.td0
file loader found!
TeleDisk_libLoad_DiskFile : Teledisk version : 21
TeleDisk_libLoad_DiskFile : Normal compression
80 tracks, 2 side(s), gap3:65535,rpm:300 bitrate:250000
track file successfully loaded and encoded!
File type : TELEDISK_TD0 - TELEDISK TD0 Loader
Floppy interface mode : GENERIC_SHUGART_DD_FLOPPYMODE - Shugart Interface
Number of Track : 80
Number of Side : 2
Total Size : 819200 Bytes, Number of sectors : 800
Stopping HxCFloppyEmulator...
But when I try to list the files I get this error:
larry@debian:~/Downloads/HxC/slim/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:ampro.td0 -list
- File image browser -
File: ampro.td0
Checking ampro.td0
Loading ampro.td0
file loader found!
Number of Side : 2
------- Disk Tree --------
Compilation error : sizeof(short)!=2
So, I tried another TD0 file named KAY2SYS.TD0
Here are the results of that command:
larry@debian:~/Downloads/HxC/slim/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:KAY2SYS.TD0 -infos
Input file : KAY2SYS.TD0
File: KAY2SYS.TD0
Checking KAY2SYS.TD0
Loading KAY2SYS.TD0
file loader found!
TeleDisk_libLoad_DiskFile : Advanced compression
TeleDisk_libLoad_DiskFile : Creation date: 19/11/1997 08:36:39
TeleDisk_libLoad_DiskFile : Comment: Kaypro 2 System Disk - SS/DD 180K
40 tracks, 2 side(s), gap3:65535,rpm:300 bitrate:250000
Number of Track : 40
Number of Side : 2
Total Size : 389120 Bytes, Number of sectors : 760
larry@debian:~/Downloads/HxC/slim/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:KAY2SYS.TD0 -list
File: KAY2SYS.TD0
Loading KAY2SYS.TD0
file loader found!
Number of Side : 2
Have you got a clue as to what could be the problem with the compilation error, or the missing dir tree?
Shouldn't there be a directory listing for both TD0 files?
I tried to do a conversion from .TD0 to .HFE and that appears to have worked just fine. I won't know for sure until
I get my slim (or other choice) purchased.
./hxcfe -finput:ampro.td0 -foutput:ampro.hfe -conv:HXC_HFE
larry@debian:~/Downloads/HxC/slim/hxcfloppyemu-code/HxCFloppyEmulator/build$ ./hxcfe -finput:ampro.td0 -foutput:ampro.hfe -conv:HXC_HFE
Output file : ampro.hfe
Checking ampro.td0
Loading ampro.td0
file loader found!
Write HFE file ampro.hfe for the standalone emulator.
Floppy interface mode GENERIC_SHUGART_DD_FLOPPYMODE (Shugart Interface)
80 tracks written to the file
Thanks.
Larry
Is it dos type images ?
ldkraemer
Post by ldkraemer »
Jeff,
The TD0 Images were created with Teledisk on a DOS machine, but the actual floppy used to create the TD0 images were as follows:
ampro.td0 was created from an actual Ampro Little Board (Z80) CP/M Machine with 80 Tracks, 2 sides, and Normal Compression.
KAY2SYS.TD0 was created from an actual Kaypro II (Z80) CP/M Machine with 40 Tracks, 2 Sides, and Advanced Compression.
Kaypro 2 System Disk - SS/DD 180K - 40 tracks, 2 side(s), gap3:65535,rpm:300 bitrate:250000
So, No they aren't DOS type Images, but are CP/M Images.
If you have somewhere I can upload them, I'll upload them so you can test with the actual images.
Thanks.
Larry
That's why you can't see files : The browser doesn't yet support CPM filesystem.
Actually only FAT12 & AmigaDOS FS are supported.
ldkraemer
Post by ldkraemer »
Jeff,
OK, Thanks. I assumed that they were included since the CLI Command existed to produce the listing.
Larry
ldkraemer wrote:Jeff,
Larry
This is working for DOS/FAT12 & AmigaDos disks, for the moment.
