SCP converted images - no index pulse?
JimDrew
Post by JimDrew »
I appears that image files converted from .scp flux images convert fine (.scp -> .hfe) but do not generate an index pulse from the hardware when using them.
I have the slim HxC updated with the latest firmware. I have it attached to the SuperCard Pro board. If I turn off the index requirement, the data looks fine (albeit randomly placed every read). I can use any of the sample images available from the HxC website and those generate an index pulse. It's just SCP conversions that do not. Is this is a known issue?
Re: SCP converted images - no index pulse?
JimDrew wrote:I appears that image files converted from .scp flux images convert fine (.scp -> .hfe) but do not generate an index pulse from the hardware when using them.
Sure this is not normal... ;)
Can you share the SCP & HFE file ?
JimDrew
Post by JimDrew »
Sure... where do I send the files?
JimDrew wrote:Sure... where do I send the files?
Let's try the email :
JimDrew
Post by JimDrew »
Done! Thanks, Jeff.
JimDrew
Post by JimDrew »
Hi Jeff... just checking to make sure you actually got the files I sent you...
Yes got it ! Sorry for my late answer, i am quite busy actually.
In fact the tracks lenght are wrong cause of the side 1 which is random. I have to do something here ;)
I will send you an image with with an "workaround".
JimDrew
Post by JimDrew »
No problem, Jeff. I don't *need* the image file, I just wanted to test the conversion to HFE and use that on my Slim HxC to feed back into the SCP. So, I was just reporting the issue to you. Thanks!
