I have an A500 and an A1200 and I'd like to be able to use it in both. I don't want to do any case modding, so I'm thinking a cased Rev C would be best and then I can just have it hanging outside of the case. I assume I'd need to find a longer floppy and power cable? If I get a cased version, is it easy to take out of the case and mount it inside the Amiga if I decided I want to do it later?
I was thinking of getting a slim but not sure I want to be limited to never having the LCD. Is it easy to mount a slim in an A500, do the mounting holes line up ok or would I need to drill my own?
