Issues with 4GB Sandisk SDHC card
rpineau
Post by rpineau »
I just got my HxC Floppy Drive Emulator from Lotharek.
I have a 128MB card that works but I have a brand new Sandisk 4GB SDHC card that seems to not work properly.
I formatted as FAT32 (on a Mac : sudo newfs_msdos -F 32 -v "Falcon HxC" /dev/rdisk1s1) but when I put the card in the HxC it says "Reading FAT ..." (or something similar as I don't have the reader on right now) and the left LED blink .... forever.
I know the reader works as it works with an only 128MB card (IO-Data).
Any idea of what can be the problem ?
Thank you,
Rodolphe
PS : you can reply in French if it's easier as I speak both French and English.
Re: Issues with 4GB Sandisk SDHC card
May i have some details about this card ? a picture ?
rpineau
Post by rpineau »
No problem, here is the card :
http://www.amazon.com/gp/product/B006E2 ... UTF8&psc=1
Regards, Rodolphe
rpineau
Post by rpineau »
Here are more infos.
This is the partition table of the 4GB card (the one with the "issue"):
Disk: /dev/disk1	geometry: 960/128/63 [7744512 sectors]
Signature: 0xAA55
         Starting       Ending
 #: id  cyl  hd sec -  cyl  hd sec [     start -       size]
 1: 0B    1   2   3 -  960  48  48 [      8192 -    7736320] Win95 FAT-32
 2: 00    0   0   0 -    0   0   0 [         0 -          0] unused
 3: 00    0   0   0 -    0   0   0 [         0 -          0] unused
 4: 00    0   0   0 -    0   0   0 [         0 -          0] unused
and the partition table of the 128MB card (the one that works) :
Disk: /dev/disk1	geometry: 995/4/63 [250880 sectors]
Signature: 0xAA55
         Starting       Ending
 1: 0B    0   1   1 - 1023 254  63 [        63 -     250803] Win95 FAT-32
The main difference is the start sector for the FAT32 partition.
I also have a 32MB card that is not recognize as FAT32 even though it is formated with a FAT32 partition :
Disk: /dev/disk1	geometry: 241/4/63 [60800 sectors]
Signature: 0xAA55
         Starting       Ending
 1: 0B 1023 254  63 - 1023 254  63 [        51 -      60749] Win95 FAT-32
Here too the first sector is different.
Does your FAT32 code assume the first sector of the first partition is sector 63 (very common but not always the case) ?
Regards, Rodolphe
Regards, Rodolphe
No, nothing is "hard coded" into the FAT layer.
I think that this more an sd init problem. The firmware you got have some improvement on this point. So try it and tell me if things are better.
rpineau
Post by rpineau »
Hi Jeff.
That's what I thought.
I should have time to install the new firmware this evening (USA - PST).
I'll report as soon as it's installed and tested with the 4GB Sandisk SD card
Regards, Rodolphe
rpineau
Post by rpineau »
Hi Jeff.
I updated the firmware with the one you sent me.
Unfortunately I still get the same result :
- 128 MB IO-Data : works
- 4GB Sandisk : still says "Reading FAT ..._" forever
- 32 MB Canon : says "Non FAT32 DS ! Please format it" even though it is FAT32 formated.
Thank you
Rodolphe.
so i must have this sd to solve the issue...
rpineau
Post by rpineau »
I can send one to you if you want. They are very cheap here so I don't mind if this helps other people. That will be my contribution to the project.
Regards, Rodolphe
rpineau wrote:I can send one to you if you want. They are very cheap here so I don't mind if this helps other people. That will be my contribution to the project.
Regards, Rodolphe
Thanks ! :)
You can find my address at the page 2 :
rpineau
Post by rpineau »
Ok no problem. I'll end it today or tomorrow. It'll come from USA so it usually take 5 to 10 days to arrive in France.
Ok Pas de problème. Je poste ça aujourd'hui ou demain. Comme ça viens des Etats-Unis ça prends 5 à 10 jours pour arrivé en France.
Regards, Rodolphe
rpineau
Post by rpineau »
Hi Jeff.
Did you ever received the 2 SD cards I sent you ?
Regards,
Rodolphe
rpineau wrote:Hi Jeff.
Regards,
Rodolphe
Yes Thanks ! I will works on this soon !
rpineau
Post by rpineau »
There is no emergency as I have a class 10 4GB SD card that works. So take your time (i'd rather use the same one as the one I sent you as class 10 is probably overkill for floppy access ;) but I have something working for now).
Regards, Rodolphe
Ok so:
The 4GB SDcard: I have corrected some stuff in the sd layer, but the main problem with this card is that some sectors are unreadable... And after some of my tests this even worst : The sdcard seems to be unwritable now ...
My advice : Please avoid this model, this seems to be a very bad sdcard ...
I can send you the corrected firmware if you want.
The 32MB SDcard : THe card is formatted in FAT12. A 32MB disk cannot be formatted in FAT32 with a normal formater.
http://support.microsoft.com/kb/314463/en
A FAT32 volume must contain a minimum of 65,527 clusters. You cannot increase the cluster size on a volume that uses the FAT32 file system so that it contains fewer than 65,527 clusters.
