Slim version user interface
seldon
Post by seldon »
I just acquired slim version of SD card emulator for my Amiga and it works great. There is just one small issue - the user interface. I love adventure games and that means even 15 disks to switch between (Beaneath a Steel Sky for example). There are two inconvenient things:
- it's hard to keep track on which disk is currently loaded
- as current disk number is indicated by number of beeps for higher disks switching becomes very slow.
Therefore i thought about using 2 digit 7 segment LED display. I planned on connecting it to 2 BCD up counters (4510) through 2 BCD to 7 segment decoder drivers (4511). Lower counters input would be connected to the switch on PCB to increase disk number. There is only one problem - I need a reset signal to set counter on 0 when user switches from the last slot to the slot 0 or if he holds the button for some time to jump straight to the slot 0. Is it possible to get such signal from the PCB somehow?
Re: Slim version user interface
In fact there is an I2C bus available on J3 to connect a front panel (for LCD, BCD display and extra key, any maybe an overlay board ;) ).
I will provide an new firmware with the LCD support soon.
seldon
Post by seldon »
Great!!! And of course it will be possible to disable beeping indicator?
seldon wrote:Great!!! And of course it will be possible to disable beeping indicator?
sure !
seldon
Post by seldon »
Any news on new firmware version?
