Sorting Files
Katsunami
Sorting Files
Post by Katsunami »
A quick question.
Does the HxC Emulator sort files when displaying the file names? At first it seems that it doesn't, but after using a different memory card it seems to now display the files in sorted order. It could be because they were copied to the new card while sorted in Explorer.
I've now made sure that the files are sorted by using DriveSort:
http://www.anerty.net/software/file/DriveSort/
It sorts the files on the SD-card itself.
I'd like to know if this utility is neccesary or not to keep images sorted, or if the HxC can do it by itself.
