EDSK/DSK are the Amstrad CPC dsk formats.joys_333 wrote: Thu Feb 20, 2020 3:19 pm I found it in this table
https://hxc2001.com/floppy_drive_emulato ... reForGotek
so the Oric DSK support is not considered?
Oric floppy images support
Re: Oric floppy images support
I have some problem to convert hfe floppy to dsk for use with emulator.
My hfe file is working on clock signal emulator but the other emulator doesn't support hfe file.
I have try to make some comparaison with dsk to hfe hfe to dsk etc and find a shift on track 20
I have uploaded the 2 files, if somebody can help me, I will be happy.
Regards.
Cyril
Regards.
Cyril
- 2Side41_17_Vierge+InitOric_hfe.dsk.zip
- (12.08 KiB) Downloaded 871 times
- 2Side41_17_Vierge+InitOric.hfe.zip
- (18.01 KiB) Downloaded 876 times
Regarding the issue it appears that you don't use the HxC Floppy Emulator hardware or firmware.
I can only provide support for HxC emulators and/or firmware users.
Hello Jeff,
Thank you for your fast response, I will try to install the HxC firmware and make a test.
Regards.
Cyril
Regards.
Cyril
Hello Jeff,
I have installed your software in my Gotek, but unfortunately it's around the same problem
The disk is not readable with OricExplorer or Euphoric.
Do you have the xml file for jasmin drive ?
Regards Cyril
Regards Cyril
You need to regenerate these HFE with the HxC tool from the DSK files.AtomeX wrote: Wed May 05, 2021 5:11 pm Hello Jeff,
Regards Cyril
Hi Jeff,Jeff wrote: Wed May 12, 2021 12:20 amYou need to regenerate these HFE with the HxC tool from the DSK files.AtomeX wrote: Wed May 05, 2021 5:11 pm Hello Jeff,
Regards Cyril
I have regenerated hfe and also make Jasmin floppy with you soft and finally after a lot of time, I have find the solution to use my hfe converted in dsk and readable with OricExplorer, Oricutron, Signalclock and probably other soft.
It's why I think the problem come from your software "HxCfloppyEmulator".
To make the dsk working I have convert hfe to dsk (Oric) and then dsk (Oric) to dsk (Oric) and the after the second pass the dsk is working
You can test the converted files.
I hope this will help.
Regards
Cyril
- DSKA0002_2sideMasterPatched_hfe_dsk.dsk.zip
- (22.74 KiB) Downloaded 837 times
- DSKA0002_2sideMasterPatched_hfe.dsk.zip
- (22.58 KiB) Downloaded 842 times
- DSKA0002_2sideMasterPatched.hfe.zip
- (42.52 KiB) Downloaded 832 times
FYI Oricutron have been just fixed. and others emulators will be fixed too i think.
