Korg Trinity + Gotek with HxC problem
Re: Korg Trinity + Gotek with HxC problem
Is the green led lit ?
What is displayed on the gotek screen?
alchemist
Post by alchemist »
The red and green leds are off, and the display (2 digits) shows the 2 last digits of the indexed files (00 to 99)
Kind Regards,
Xavier Miller
alchemist wrote: Thu Nov 30, 2017 12:11 am Hi,
Which images are you using ?
alchemist
Post by alchemist »
I used raw files (dd if=/dev/floppy of=floppy.img ; or created by mtools), converted to HFE format, and readable with the HxC converter.
I renamed them as requested, to be indexed.
The bootloader and firmware (3.0.8.2a) are the latest for Gotek (as specified in the documentation).
I've put the config file for indexed mode
I will test it on a PC to see if it works and will go back to you.
PS: I've also ordered a SPI 128x32 display to see what happens.
Kind Regards,
Xavier Miller
Is the korg trying to read the disk ? The green led should lit when you try to read the image.
alchemist
Post by alchemist »
I will check it again this evening. Thank you for your support!
Kind Regards,
Xavier Miller
alchemist wrote: Thu Nov 30, 2017 12:41 am PS: I've also ordered a SPI 128x32 display to see what happens.
Hope that this is just a typo. Only I2C/IIC are currently supported
alchemist
Post by alchemist »
This is a typo : it's a "0.91" IIC I2C Serial SPI OLED LCD Display 128x32 3.3V/5V AVR PIC STM32 Arduino" item on ebay
Kind Regards,
Xavier Miller
alchemist wrote: Thu Nov 30, 2017 10:08 am This is a typo : it's a "0.91" IIC I2C Serial SPI OLED LCD Display 128x32 3.3V/5V AVR PIC STM32 Arduino" item on ebay
ok !
alchemist
Post by alchemist »
Hi!
I am testing on a PC before to test it on my synthesizer and still cannot read the images.
I created 2 images files with HxCFloppyEmulator, 1.44 PC diskettes, with 2 different contents.
I loaded the firmware HXCFEUSB_V3_0_33_12a.UPD with the related config file for indexed mode
The drive has a S0 jumper enabled. The green led is lit, and the display shows 00 or 01 following the selection buttons.
But when I try to read the diskette, I have that:
$ mdir
Can't open /dev/fd0: Aucun périphérique ou adresse
Cannot initialize 'A:'
and dmesg shows
[  332.749045] print_req_error: I/O error, dev fd0, sector 0
[  332.749049] floppy: error 10 while reading block 0
What's wrong?
Kind Regards,
Xavier Miller
alchemist wrote: Thu Nov 30, 2017 9:52 pm Hi!
$ mdir
and dmesg shows
What's wrong?
For PC you must use the S1 jumper.
And if the green is always lit, please reconnect the floppy ribbon to the other side.
alchemist
Post by alchemist »
It's working on the PC !
I am using a raw image and can at least dir:
$ mdir
 Volume in drive A is TFD-00P
 Volume Serial Number is 1C51-18CB
Directory for A:/
PRELOAD1 PCG    261901 1995-11-15   0:00
PRELOAD1 SNG    476612 1995-11-15   0:00
PRELOAD2 SNG    377618 1995-11-15   0:00
HELLO    TXT        15 2017-11-30  21:41  hello.txt
        4 files           1 116 146 bytes
                            340 480 bytes free
$ mount /dev/fd0 /mnt ; cat /mnt/HELLO.TXT ; umount /dev/fd0
Hello, World!
Kind Regards,
Xavier Miller
alchemist
Post by alchemist »
Now on the Trinity, we are going further : in Disk mode, I can see the contents of each diskette.
But when I want to load a file, the synth complains "Medium changed".
I cannot do any action except refresh the file list.
The config file is the default for indexed mode, the jumper is on S1 as requested on the support page.
What info do you need to help me?
Kind Regards,
Xavier Miller
alchemist wrote: Thu Nov 30, 2017 11:05 pm Now on the Trinity, we are going further : in Disk mode, I can see the contents of each diskette.
Try to add a jumper to the "MO" jumper position.
alchemist
Post by alchemist »
I have the same results with the MO jumper set.
Kind Regards,
Xavier Miller
