Acorn A3000
stomachcontents
Re: Acorn A3000
Post by stomachcontents »
Jeff!
Your suggestion worked! IT WORKS!! HAHA! So happy! :D :D :D
So is this something I should have changed in my config file or is the only way to fix it to do the config on the actual HxC?
By the way I have a A3010, not a A3000. Posted here because the problem sounded similar to the issues some people had with the A3000.
Here's a pic of my drive in case it helps..
Thanks again Jeff!!
alienkidmj12
Re: Acorn A3000
Post by alienkidmj12 »
Does this mean hxc works on a3000
Re: Acorn A3000
alienkidmj12 wrote: Wed Nov 15, 2017 12:42 am Does this mean hxc works on a3000
For sure it does. Just a question of setting.
alienkidmj12
Re: Acorn A3000
can someone help me out configuring hxc2001, im struggling here,
i can get it to recognise my 8gb card to start with, so im doing a full format :)
dave
alienkidmj12
Re: Acorn A3000
still unable to see files, all i get is choose a file, i know there are lots of adf files on there just cant see them, ive managed to install the latest beta firmware though.
Re: Acorn A3000
alienkidmj12 wrote: Sat Dec 09, 2017 5:04 pm still unable to see files, all i get is choose a file, i know there are lots of adf files on there just cant see them, ive managed to install the latest beta firmware though.
Which HxC are you talking about exactly ?
alienkidmj12
Re: Acorn A3000
i have a drive from lotharek, type f connected to the acorn a3000. i have jumpers id0a through id3a set to on, i have "no disk" message when trying to read disk, if i set first jumper on it seems to read sometimes but then locks up the os :( not having much luck here folks, does this support a3000 or not :(
alienkidmj12
Re: Acorn A3000
got it working on custom mode, pin 2 and 34 to low, also pin id0a set to on only.
number-one
Re: Acorn A3000
Post by number-one »
Hello I am newbie user of an Archimede A3010 4MB Ram without hard disk.
I have 1 slim HXC and 1 REV C HXC.
I am lost, what are the jumpers, floppy cable and software settings to read Acorn Disk Image ?
