HXC Slim drives A+B together on Amiga
Re: HXC Slim drives A+B together on Amiga
Arnie wrote:Sorry to say this but, the latest firmware didn't make any difference.
I still need to have the SD card inserted and a non bootable AUTOBOOT.HFE file loaded at startup for DF1: to show up.
Its the same without the HD connected.
The good firmware is incoming :wink:
Arnie
Post by Arnie »
Look forward to it :wink:
In your email box :D !
Arnie
Post by Arnie »
Success :D, the latest firmware V2_1_2_2a works a treat. :mrgreen:
I can here both drives clicking and DF1: is mounted without a card inserted 8)
Thank you Jeff.
P.S. Not important but, could it be possible, in future updates, to allow inserting a disk in drive B without a disk inserted in drive A
seldon wrote:I just wanted to write, that all my problems have been solved. I received my HxC from Lotharek back and everything works as before, as well as both drives A and B. The problem was probably my SD card.
Thanks for the feedback.
I got your sdcard here to study it in order to check there is a compatibility problem.
Compatibility problem solved. You have the new firmware in your email box!
seldon
Post by seldon »
Is there a changelog for this firmware version available? Does it address only support for 2 drives emulation or also other changes? I look forward particularly for support of 7-segment display via I2C?
