Arburg Multronica
Re: Arburg Multronica
Garrit wrote: We use that but then I have only one track. How do I combine the raw-files of the other 159 tracks what was on the disk?
Nothing. Just load one raw file, the others are loaded as well.
Note : All raw files must be in the same folder.
Garrit
Post by Garrit »
Thanks, I will give it a try.
marvell80
Post by marvell80 »
Hello. I read the thread very carefully. I am using HXC Rev C cased. Followed all of the procedures mentioned above for creating image of my Arburg floppy disk. The problem is that the machine start reading it but in the end failed and then restarted.
marvell80 wrote:Hello. I read the thread very carefully. I am using HXC Rev C cased. Followed all of the procedures mentioned above for creating image of my Arburg floppy disk. The problem is that the machine start reading it but in the end failed and then restarted.
First try the images into this archive :
marvell80
Post by marvell80 »
Hello. The tested controller using only one floppy disk not three. Also every control has custom starting disks. I tested your images but without luck.
marvell80
Post by marvell80 »
Any other ideas are appreciated.
biernak
Post by biernak »
I have a problem....
I can't buy KRYO FLUX...they did not answer my email....
can I use CATWEASEL MK4 PLUS or something else ?
I have Lotharek SD HxC Floppy Emulator, and I would like copy system disk to SD card.
biernak wrote: Fri Sep 29, 2017 12:11 am Hello,
The kryoflux online store doesn't work ?
arteitle
Post by arteitle »
biernak appears to be correct, the KryoFlux board isn't available for sale on the KryoFlux store any longer: https://webstore.kryoflux.com/catalog/index.php?cPath=1
arteitle wrote: Thu Oct 12, 2017 3:52 pm biernak appears to be correct, the KryoFlux board isn't available for sale on the KryoFlux store any longer: https://webstore.kryoflux.com/catalog/index.php?cPath=1
Then this definitively means that i have to finish an unfinished project as alternative...
arteitle
Post by arteitle »
Never mind, it appears to be back! It currently says "coming soon, ships within 3-5 working days after Monday 23 October, 2017".
arteitle wrote: Tue Oct 17, 2017 6:48 pm Never mind, it appears to be back! It currently says "coming soon, ships within 3-5 working days after Monday 23 October, 2017".
Ok!
jdmcnulty
Post by jdmcnulty »
Hello Jeff and everyone else.
I have read this thread in great detail - downloaded all the required files and am planning to perform this upgrade on my Arburg multronica machine.
I have a few questions on the procedure, and may need some additional advice.
In order to perform this upgrade I need to do the following steps:
1) purchase HxC Floppy Emulator (REV F)
2) purchase Kryoflux -- https://webstore.kryoflux.com/catalog/p ... ucts_id=30
3) purchase Panasonic JU-257A607P floppy disc drive
4) use Kryoflux and Panasonic floppy disc drive to create RAW files from my existing Arburg Program and System Disks (2 disks)
5) use HxC software to convert the RAW files to HFE ??
6) write HFE files to SD card
7) install HxC Floppy Emulator (REV F) into Multronica control unit
8) connect SD card w/ HFE and read
Is this correct? I am awaiting confirmation - or adjustments to my process and I will begin purchasing all the components. If needed, I can send the disks to Jeff, to have them read - whatever is the preferred method.
Thanks in advance, and I appreciate your time,
Jason
jdmcnulty wrote: Mon Oct 30, 2017 6:40 pm Hello Jeff and everyone else.
Jason
The process is good. If you need any help for the step 5 you can contact me for the conversion.
jdmcnulty
Post by jdmcnulty »
Thanks Jeff. Everything is ordered. Look forward to the project.
