2.8" QD Disk Emulation
Re: 2.8" QD Disk Emulation
etaoin wrote: Tue Sep 17, 2019 5:04 pm Trick firmware results. Verify error on both and unreadable (I/O Error 2)
Interesting. the tracks are truncated and this shouldn't happen with this trick : 2 possibilities :
-> i failed with the trick.
or
-> the write pipeline this not completely flushed to the track.
will check this in some hours.
AMSynths
Post by AMSynths »
Hi, I dont plan to do any further traces as Jeff has the logic analyzer rigged up nicely. I will test any files and fw. :-)
Shout if you need me to trace anything on the analog scope.
AMSynths wrote: Tue Sep 17, 2019 7:11 pm Hi, I dont plan to do any further traces as Jeff has the logic analyzer rigged up nicely. I will test any files and fw. :-)
Yes :) . In fact there is almost all the needed informations in the logic analyser dump file. We still have to resolve the short ready signal event mystery and maybe some do some comparisons with the gotek if the following firmware doesn't solve the last issue.
Jeff wrote: Tue Sep 17, 2019 5:13 pm
or
Checked and the trick was ok, but there was a bugs so attached a firmware fixing some timings issues related to the ready signal.
EDIT : Removed !
Try it with this image :
viewtopic.php?f=2&t=773&start=390#p21423
and this one too :
viewtopic.php?f=2&t=773&start=390#p21421
etaoin
Post by etaoin »
Verify error on both. They do read back fine.
EDIT : test8a.zip removed !
etaoin wrote: Wed Sep 18, 2019 7:54 am Verify error on both. They do read back fine.
Same with these ?
EDIT : Removed !
If so, i will need the gotek traces to compare because i ran out of idea for the moment... :?
etaoin
Post by etaoin »
Yes, verify error on all, read back ok
EDIT : test37.zip removed !
etaoin wrote: Wed Sep 18, 2019 8:30 am Yes, verify error on all, read back ok
a last one to be sure...
EDIT : Removed !
etaoin
Post by etaoin »
And
etaoin
Post by etaoin »
Written
EDIT : DSKA0008.QD.zip removed !
Ok Gotek Traces needed then.
This thing is crazy :lol:
etaoin
Post by etaoin »
I'll see if I can find some time today to wire up the gotek for tracing.
All the last files are valid.
btw is there a "verify" function like in the x7000 ? : I mean a verify function that check the QD content ?
etaoin
Post by etaoin »
Jeff wrote: Wed Sep 18, 2019 8:44 am btw is there a "verify" function like in the x7000 ? : I mean a verify function that check the QD content ?
No, probably because it does that automatically after a save.
There is a "QD Monitor", but that only shows the contents (sample name) and which bank the disk belongs to. It doesn't actually verify the disk.
There is a confusingly named "Quick save without verification" but that only skips the overwrite check, not the verification.
False verify failure wouldn't be bad if the loads are always fine, but the problem is the S10 needs multiple disk(-sides) for all but the shortest sample, and it won't allow a disk change after a verify error.
Interesting thing in the last files : It appears that there was 2 writes attempts. But the first one appears quite late/shifted... Is it a features ? :) (In how many seconds do you get the verify error message ?)
(Waiting for the traces to confirm).
