2.8" QD Disk Emulation
hoby
Re: 2.8" QD Disk Emulation
Post by hoby »
Jeff wrote: Thu Sep 12, 2019 9:52 pm another one
blankKing_NM16.zip
NM16: Negative
And this one ?
EDIT : blankKing_NM17.zip removed !
hoby
Post by hoby »
NM17: Negative as well
attached !
EDIT : blankKing_NM18.zip removed !
EDIT : blankKing_NM19.zip removed !
hoby
Post by hoby »
Nm18; No
NM19: No
Neither loaded
Attached
EDIT : patch_wrsplice4.zip removed !
(Have you an LCD/OLED screen ?)
hoby
Post by hoby »
NM10: No
NM21: No
NM22:No
NM23: YES!
NM23 loaded. I have the OLED in my drive
hoby wrote: Fri Sep 13, 2019 8:10 am NM10: No
NM21: No
NM22:No
NM23: YES!
Ok more tests.
EDIT : patch_sync1.zip,patch_sync2.zip,patch_sync3.zip,patch_sync4.zip,patch_sync5.zip removed !
( The non-working cases are also interesting to understand how this controller is syncing on the track ;) )
hoby
Post by hoby »
NM24: --
NM25: --
NM26:--
NM27:--
NM28:--
NM29: OK
NM30: OK
NM31: OK
NM32: OK
NM33: OK
NM34. OK
NM35:--
NM36: Missing
NM37:--
NM38:--
NM39:OK
NM40:OK
NM41:OK
NM42:--
NM43:OK
NM44:--
Lots of good ones this time. For some reason 42 did not work,...
Thanks a lot !
Can you now try to write on these images and read them ( and share them here) ?
EDIT : bitrate.zip removed !
hoby
Post by hoby »
SO: Save OK - Load&Verify:Fail
S1: Save OK - Load&Verify:Fail
S2: Save OK - Load&Verify:Fail
S3: Save OK - Load&Verify:Fail
S4: Save OK - Load&Verify:Fail
S5: Save OK - Load&Verify:Fail
S6: Save OK - Load&Verify:Fail
S7: Save OK - Load&Verify:Fail
Yup, here you are. Very similar result at my end
EDIT : S4toS7.zip & S0toS3.zip removed !
Can write on this one and share it ?
EDIT : blank_S8.zip removed !
(I am preparing you a firmware with some debug stuff on the oled screen).
hoby
Post by hoby »
Here you are. The debug thing sounds interesting
EDIT : blank_S8.QD.zip removed !
hoby wrote: Fri Sep 13, 2019 9:13 pm Here you are. The debug thing sounds interesting
Attached a firmware showing you on the first line how many times the write gate signal changed. First number : WG assertion, second number : WG deassertion.
Try to write on blank_S0.QD for example.
Should be "001 001" after a write attempt, but i think that we will have some surprises.
Change/eject the image to reset the counters.
EDIT : Removed !
hoby
Post by hoby »
S0 to S8: all have the result 001 001, so I guess it is how it should be.
all of them flipped the WG-assertion shortly after the "disk active" led light went on.
all of them flipped the WG-deassertion at the time when the "disk active" led light went out.
