2.8" QD Disk Emulation
Re: 2.8" QD Disk Emulation
hoby wrote: Wed Sep 11, 2019 11:55 pm No, unfortunately it is still the same
And this one ?
EDIT : blankKing_NM2.zip removed !
hoby
Post by hoby »
Bingo!! It Worked. Both loading and verification is sucessfull.
hoby wrote: Thu Sep 12, 2019 8:07 am Bingo!! It Worked. Both loading and verification is sucessfull.
:shock: :D
Ok Let me patch again some files to confirm : This appears to be a one bit shift issue at the beginning of the sync word ...
And with these ones ?
EDIT : blankKing_NM3.zip & blankKing_NM4.zip removed !
hoby
Post by hoby »
Jeff wrote: Thu Sep 12, 2019 8:33 am And with these ones ?
I have to attend that work thing, but will try it first thing when I get home. Exciting times!
hoby wrote: Thu Sep 12, 2019 10:11 am
Yes i know now where to have a closer look. This will probably also help to fix the issue with the Roland machines since the issue is directly related to the MB87013 and how its synchronisation is working.
hoby
Post by hoby »
NM3 works
NM4 does not work
More images to test.
EDIT : patch_wrsplice.zip removed !
hoby
Post by hoby »
Jeff wrote: Thu Sep 12, 2019 8:47 pm More images to test.
NM2 OK
NM3 OK
NM4: No
NM5: No
NM6: No
NM7: No
NM8: No
So only the 2 first have worked so far
And more files !
EDIT : patch_wrsplice2.zip removed !
And again !
EDIT : patch_wrsplice3.zip removed !
hoby
Post by hoby »
Jeff wrote: Thu Sep 12, 2019 9:28 pm And more files !
patch_wrsplice2.zip
Can you upload it again. For some reason I cant open it
hoby wrote: Thu Sep 12, 2019 9:35 pm
patch_wrsplice2.zip
EDIT : patch_wrsplice2.zip & patch_wrsplice3.zip removed !
another one
EDIT : blankKing_NM16.zip removed !
hoby
Post by hoby »
NM9: No
NM10: No
NM11: No
NM12: No
NM13: No
NM14: No
NM15: No
All negative.
