2.8" QD Disk Emulation
a12bitproduction
Re: 2.8" QD Disk Emulation
Post by a12bitproduction »
I might be able to provide pics of my S700 as well but not before friday. Good to see it's in development :)
winsten
Post by winsten »
jeff i can send you my s220 drive so you can get measurements and the form factor correct when ever you guys start work on the actual casing .
a12bitproduction
Here are some pictures. I'm no engineer so you have to tell me what you need. You can download a pack of highrez versions here.
chaziv62
Post by chaziv62 »
I have (10) Roland MKS100's, (1) MKS220 and (2) S10's. I will give you (to keep) a MKS100 if you will develop the QD emulator.
I have a huge library that you could use to test the functionality.
I am still working on this :D
There is a main difference between the classical floppy emulator and the QD floppy emulator : Most of the machines with QD disks use a custom track/sector encoding. This mean that the hardware must be able to dump the data in stream mode from the original disks ! So the device MUST have both functions : emulation and disk dumping !
13bit
Post by 13bit »
I have Akai S700 with ASK-70 board.
On each side of the Quick Disk is saved one sound. How do you intend to save the program with a few sounds? It would be great to keep the all contents (up to 6 or 16 sounds and programs) or full dump of memory!
I wish you good luck in the QD-emulator development!
Junigtron
Post by Junigtron »
What is the state of this project? I also have x7000 collecting dust. Thumbs up for your efforts so far!
mcSDHXC
Post by mcSDHXC »
Hi there
Was this project completed? I have a Roland PR-100 and would like to replace the 2.8 inch QD with an HxC flashed Gotek. I already have a firmware license as I use a HxC flashed Gotek in my Amiga A1200.
Thanks..
5U-7_(7ON)
Post by 5U-7_(7ON) »
massive bump!!!! :D got an s700 just waiting for one of these babies <3
themilford
Post by themilford »
I will gladly donate an Akai HD280 QD drive to this cause. I would let that person borrow one of my S612 samplers for testing. This NEEDS to happen.
themilford wrote:I will gladly donate an Akai HD280 QD drive to this cause. I would let that person borrow one of my S612 samplers for testing. This NEEDS to happen.
Interested by your proposition ! :D
themilford
Would shipping to France be prohibitive?
themilford
So, I got both Akai Quick Disk drives working.
Replaced belts. Got them from here:
https://console5.com/store/akai-roland- ... -belt.html)
A quick swab of the heads with some isopropyl and they load my one Akai Sound Library disk I have perfectly. It took a few tries but after the units warmed up they seem to load and save samples fine. I ordered all new transistors, regulators and caps for the power supplies in the samplers... the PSU in the samplers powers the drives as well. One sampler I have seems to be working fine but will also have it's PSU refurbished.
If these things are this easy to fix, I might not be in a super hurry to have an HxC made... and supposedly the final OS version allows sysex dump of the samples via midi. But if somebody want's to work out borrowing a drive and sampler hit me up, we should work something our for the future of these awesome devices.
themilford
Also, ere is some interesting info:
http://www.wiseguysynth.com/larry/s-612/s-612.htm
mcSDHXC
Post by mcSDHXC »
Hi Jeff
Are you still working on this project? I've ordered a replacement belt for my PR100 but would prefer to replace the drive with a floppy emulator.
Happy to help in any way I can - just let me know.
