Amiga Floppy Manager freeze
mauroxavier
Re: Amiga Floppy Manager freeze
Post by mauroxavier »
I tried only on a MSX 1, and I can't format a floppy, give me a error.
Since it is necessary the index signal to format a floppy in MSX, i think it is really a hardware error, and unfortunately I am not being able to fix it.
Tomorrow I will try something else, but I'm getting disappointed and I end up using only the lcd manual searches.
I appreciate all your help, and I have no doubts about the quality of the hardware. It was probably something the previous owner did wrong.
danko
Post by danko »
@ mauroxavier
you have solved the problem? I have a same problem with the HxC and Amiga 600.....look forward to hearing from you....
danko wrote:@ mauroxavier
Are you sure ?
danko
Post by danko »
Are you sure ?
You remain fixed on the written direct access, and will not let me select the file with the button, except that now no longer works is useless ..... I tried to reprogram the PIC has been successful, only that the display no longer lights, and lights a green led, perhaps you need to configure some settings in the pic but would not know which....
Are you sure ?
To disable the autoboot mode : overwrite/replace the HXCSDFE.CFG file on the SDCard.
Otherwise : Do you have something like this when you start the autoboot.hfe ? :
http://www.youtube.com/watch?v=p1zP6p9SBLw ?
danko
Post by danko »
Yes I have tried to format sd card and I put all new files, not a software problem but hardware is left in something short, some components do not work anymore ...
danko wrote:Yes I have tried to format sd card and I put all new files, not a software problem but hardware is left in something short, some components do not work anymore ...
mhh ? what did you do ?
danko
Post by danko »
I soldered the wires when I tried to connect the buttons on the PCB from there, something happened ...
