Posts: 8247 Joined: Fri Oct 20, 2006 12:12 am
Post
by Jeff » Mon Dec 13, 2010 12:13 am
Yes and where did you connect the hxc ?
reminder:
If non-twisted floppy "connector" of the cable:
A: -> ID2
B: -> ID1
If twisted floppy "connector" of the cable:
A: -> ID1
B: -> ID2
mau_rizio
Posts: 69 Joined: Tue May 05, 2009 5:08 pm
Post
by mau_rizio » Mon Dec 13, 2010 12:21 am
Connected to the last connector, the one after the twist.
The red wire is on the right near the id jumpers.
If i set ID2, the bios says "Floppy disc failed".
Post
by Jeff » Mon Dec 13, 2010 12:26 am
mau_rizio wrote: Connected to the last connector, the one after the twist.
ok.
under msdos you can read the floppy disk ?
Or can boot an msdos floppy image?
Post
by Jeff » Mon Dec 13, 2010 12:37 am
Jeff wrote: mau_rizio wrote: Connected to the last connector, the one after the twist.
ok.
Another point :the HFE file interface setting is set to "IBM PC 1.44MB" or "IBM PC 720KB" ?
mau_rizio
Post
by mau_rizio » Mon Dec 13, 2010 1:20 am
ok.
I got no boot disk images, i got only real dos floppy.
Do you know where i can find a boot image?
Don't know because i selected Create FS Floppy, 720Kb msdos, injected the directory, export.
Post
by Jeff » Mon Dec 13, 2010 8:17 am
mau_rizio wrote: Jeff wrote: mau_rizio wrote: Connected to the last connector, the one after the twist.
ok.
http://www.allbootdisks.com/download/dos.html
->Menu Settings
->"SDCard HxC Floppy Emulator Settings"
-> Select AUTO
->After Load your hfe file on the main window
->The interface mode of the file is indicated in the "SDCard HxC Floppy Emulator Settings" window.
mau_rizio
Post
by mau_rizio » Mon Dec 13, 2010 11:36 am
Don't work, the pc does a little access to the hxc then windows load (but it works with another sd).
Post
by Jeff » Mon Dec 13, 2010 11:56 am
mau_rizio wrote: Don't work, the pc does a little access to the hxc then windows load (but it works with another sd).
Which firmware version can you read on the hxc floppy emulator display ?
Again : Can you measure the 5V PC power supply ?
And give me the exact SDCard brand/model number.
mau_rizio
Post
by mau_rizio » Mon Dec 13, 2010 1:14 pm
Jeff wrote: mau_rizio wrote: Don't work, the pc does a little access to the hxc then windows load (but it works with another sd).
1.3.1.0b
Yes, tell me where to test
SanDisk sdhc 4GB c4 - BH1020916046G
Post
by Jeff » Mon Dec 13, 2010 1:31 pm
Red and black wire of the PSU floppy connector.
mau_rizio
Post
by mau_rizio » Tue Dec 14, 2010 12:39 am
4,97
But the hxc has power even if it's connected with just the floppy cable?
Post
by Jeff » Tue Dec 14, 2010 1:14 am
mau_rizio wrote: 4,97
You need the power supply cable to powered the hxc floppy emulator.
the emulator may be powered by the floppy cable, but this is only a side effect.
mau_rizio
Post
by mau_rizio » Tue Dec 14, 2010 3:29 pm
I can send you the card, if you think this can help you to investigate the problem.
I have an identical card with the same problems so i can help you with tests.
Post
by Jeff » Tue Dec 14, 2010 9:01 pm
mau_rizio wrote: I can send you the card, if you think this can help you to investigate the problem.
Ok thanks for this.
I will recontact you once i get the sdcard and the solution.
