Gotek rebooting Roland S-550 after disk load.
Jidis
Re: Gotek rebooting Roland S-550 after disk load.
Post by Jidis »
Jeff wrote: Thu Sep 10, 2020 7:41 amPlease zip and password protect the files ( + with the option to hide the files name).
Resent, though I couldn't hide the names in 7-zip. Password is in the email.
- Is the S550 crashing at the system disk reading or also when reading data disk ?
Yes, it can crash when loading the utility or sequencer disks as well as the sound disks.
- Is the S550 always crashing at the same point ?
- Is the S550 crashing randomly while loading the disk ? Or it is at the beginning ? Or at the end ?
- If this is at the read beginning, does it read something ? (how much tracks ?)
The 550 can hold two disks. It chain loads both disks when it boots up. It always loads through the first one, then right when it gets ready to throw up the "Next disk please" message, all the lights flash and it reboots itself. It might be worth noting that the utility and sequencer disks don't go into "chain load" or ask for that second disk when they're done loading, but it still crashes right when they finish.
- When you bootup the S550 i suppose that the gotek load automatically the image from the stick. Does the S550 crash if you power up the whole thing and then insert the usb stick some seconds latter ?
I've done that before, but just double checked. Yes, it will still crash if the stick is inserted after it has booted.
Ok. So now i am not sure to understand the "after loading the first disk" in the first post. This means that if the "first disk" is correctly loaded the S550 never crash in the next data disk loading ?
Still received nothing. I will send you by email an ftp account to push the files.
EDIT : Email sent, let me know if you have received it.
Jidis
Post by Jidis »
Jeff,
Got the mail, but don't have an ftp client on here to upload with. I just resent the attachment using my Yahoo mail, so maybe that one will get through.
Jidis wrote: Thu Sep 10, 2020 8:41 pm Jeff,
Nothing...
Add a password to the zip and change the zip file extension.
Another question : You said that this was working correctly in the past with IMG files. Is this sure ?
Jidis
Post by Jidis »
Jeff wrote: Thu Sep 10, 2020 9:22 pm Another question : You said that this was working correctly in the past with IMG files. Is this sure ?
No, I'm not sure at this point. It ran for a couple years or more on HFEs with no issues though. I didn't put new firmware on it and start trying to use IMGs until more recently.
Jidis wrote: Thu Sep 10, 2020 10:20 pm
ok. Can you share these images somewhere ? I really need them to go further.
Jidis
Post by Jidis »
Jeff wrote: Thu Sep 10, 2020 10:21 pm ok. Can you share these images somewhere ? I really need them to go further.
Should be on the ftp now. It's called "rebooter.zip".
what is the zip password ?
Jidis
Post by Jidis »
Oh, sorry Jeff- The password is Jidis
Jidis wrote: Thu Sep 10, 2020 10:45 pm Oh, sorry Jeff- The password is Jidis
Thanks. First interesting thing: The HFE seems formatted from the S550, which is good since i can see the real sector interleave.
I will compare with the Gotek now.
And of course there are differences.
First fix attempt. (v3.5.1.12)
HxCUSBFE.UPD
(89 KiB) Downloaded 463 times
Jidis
Post by Jidis »
Jeff,
I've done about fifteen boots now with that 3.5.1.12 with no crashes (all IMG files). I'll keep trying off and on through the night and let you know if it does.
Thanks Again
Jidis wrote: Fri Sep 11, 2020 1:38 am Jeff,
Thanks Again
ok fine ! Let me know, then i will release the fix.
(Finally this was "just" the disk layout definition to change. Apparently this machine seems to be very sensible towards to the sectors interleave and tracks skew...)
Fix validated by Jidis.
New release :
viewtopic.php?p=22956#p22956
