Hard sector format
Re: Hard sector format
Can we put here the exact supposed layout/format ?
I mean something like this (for example):
[Preamble Byte 0x00 * 12][ID Mark 0xAA * 2] [Track Number][Side Number][Data Sector (256][CRC Low][CRC High][GAP 0xFF * 16]
That's a good idea. I'll work it up and try to post this evening. Re: Trailing gap. I do not believe this concept is relevant for hard-sector formats since the controller is expected to re-sync after each index pulse.
Here is a compilation of everything known about the Northstar DD format:
Northstar DD floppy format
10-sectors per track x 35 tracks per side
MFM encoding
Single and double-sided formats are supported
Data Layout
[Sector index (rising edge)]
[96 us delay]
[Preamble = 33 Bytes of 0]
[Sync 0xFB 1-byte]
[Track-Sector 1-byte (see below)]
[Data 512-bytes]
[Checksum 1-byte (see below)]
There is no formal padding at the end of the sector. In a hard-sector
format the diskette controller is expected to re-sync on the next
index hole.
Track-Sector Byte Detail
Bits 0-3 = Sector (0..9)
Physical Order from rotational index: 0 2 4 6 8 1 3 5 7 9
Bits 4-7 are related to the track.
On side 0 of a diskette, the value in bits 4-7 cycles through the
sequence: 0x0 0x4 0x8 0xC as track advances. In other words,
tracks 0, 4, 8, 12, 16, 20, 24, 28, 32 have a value of '0x0' in the
upper four bits. Tracks 1, 5, 9, 13, 17, 21, 25, 29, 33 have a value
of 0x4 in the upper bits, etc.
On side 1 of a double-sided diskette, the value in bits 4-7 cycles
through the sequence: 0x1, 0x5, 0x9, 0xD as we advance inward from the
outermost track. This amounts to the same pattern shown above, but
with bit 4 set to denote the second side of the diskette.
Checksum Byte Detail
The checksum algorithm works as follows:
// Sector data
unsigned char data[512];
unsigned char csum = 0;
for (int i=0; i<512; i++) {
csum = csum ^ data[i];
csum = (csum << 1)|(csum >> 7);
// Resulting value is written to diskette as the checksum byte.
Logical data organization on double-sided diskette
Data is written in a serpentine order:
Side 0: Track 0..34
Side 1: Track 34..0
NOTE:
The Northstar technical documentation has a discrepancy between
figures and text. Figures 3-4 and 3-5 show the layout for DD MFM
diskettes with 512-byte sectors. The text references an older SD FM
format with 256-byte sectors.
The document you are reading now is intended to cover the DD MFM
512-byte format.
Hi, Jeff. You should have what you need now (see previous message).
This seems perfect.snhirsch wrote: Mon Nov 06, 2017 6:51 pm Hi, Jeff. You should have what you need now (see previous message).
I presume that the sync word have no missing clock ?
Good question about the missing clock. I think we may have to settle that by experimentation. Neither the FC-5025 nor Catweasel code cared about this, since they were simply counting bit cells. Let's assume it's not missing for the first try.
This would be simpler if the Kryoflux people were willing to support hard-sector formats. They seem convinced that a special drive mechanism is required, but that's simply not correct. There were some older 8" drives with on-board data separators for hard sector formats, but that capability is not required to read flux transitions.
Hi, Jeff.
Has there been any progress on hard sector support? FYI: I have been contacted by the Kryoflux folks and asked to supply them with example media for analysis. Maybe we'll get lucky and they will add support.
still busy with the stm32 firmware.snhirsch wrote: Fri Dec 01, 2017 5:15 pm Hi, Jeff.
https://forum.kryoflux.com/viewtopic.php?f=3&p=12415snhirsch wrote: Fri Dec 01, 2017 5:15 pm Hi, Jeff.
@snhirsch[...]
We might be also looking into supporting "real" hard-sectored formats (where the sector index information was actually used), but reliable/low-level information is pretty scarce on those, and we simply do not have any such disk.
Do you you think that you will able to "tweak"/make changes into the track encoder once i will release it ?
will be faster since i don't have this machine nor any disk to make working at the first release...
Also very interested in any progress on supporting hard sector format disk emulation! I have the SD card emulator from Lotharek.
I have an Exidy Sorcerer with 40x10x512 hard sectored disk access trough a Vista S-100 bus FDC. It came with a few dozen hard sectored disks but many of them are disintegrating and/or failing. It would be great to 1) archive the software on these disks and 2) be able to keep using original hardware. It is basically CP/M but some of this software is specific to the Sorcerer.
New hard sectored floppy disks are impossible to get. There have been some initiatives creating a device to punch in the extra holes needed for hard sectoring using soft sectored disks, but nothing available currently. Another development is separate logic to create the extra pulses (see here). This only works with "modern" floppy drives (perhaps also with an HxC?).
I could help sending a hard sectored floppy disk to you if that would help...
Join the club of folks waiting for hard-sector support
. FWIW: The sector pulse generator does NOT work with HxC. That was one of the first things I tried. The Kryoflux folks recently added support for capture of RAW hard-sector images. This does not help with data extraction, but does provide complete details on the flux layout. I've captured images from Heath and Northstar hard-sector diskettes and sent them to Jeff.
Thanks for the input on the combination of pulse generator and HxC! It would be great if support would be added. The number of Sorcerers is declining and so is the availability of software for these machines, would be nice if some of it could be saved.snhirsch wrote: Mon Apr 30, 2018 12:20 am Join the club of folks waiting for hard-sector support. FWIW: The sector pulse generator does NOT work with HxC. That was one of the first things I tried. The Kryoflux folks recently added support for capture of RAW hard-sector images. This does not help with data extraction, but does provide complete details on the flux layout. I've captured images from Heath and Northstar hard-sector diskettes and sent them to Jeff.
I never saw this message. I'm a reasonably competent software engineer and would be glad to help in any way I can. At one point I checked out all the source code for Floppy Emulator, but without a high-level overview it was really difficult to make sense of. With some guidance I'd be happy to dive in further.@snhirsch
well i need to fix the kf stream importer and then you should be able to emulate the drive in read-only mode from the stream.snhirsch wrote: Mon Apr 30, 2018 10:50 pmI never saw this message. I'm a reasonably competent software engineer and would be glad to help in any way I can. At one point I checked out all the source code for Floppy Emulator, but without a high-level overview it was really difficult to make sense of. With some guidance I'd be happy to dive in further.@snhirsch
Good to hear! Hopefully that will be ready soon and full R/W support not too far behind
