Technics KN 2000 / Disk Change
Re: Technics KN 2000 / Disk Change
Is there any relation/point with the HxC Floppy Emulator ?
rdoctor
Post by rdoctor »
sambell wrote:Hello, Roberto, I went through some of those problems and finally discovered there was a discrepancy on the wiring diagram. Pin 9 on the KN2000 should be connected to pin 32 of the emulator. When I made that connection, it worked perfectly. Please let me know how it works.
Sam
Hi sambell, as you can read, I have bought an adapter with a connection between pin 9 of the kn2000 and pin32 of the emulator. Now it doesn't work, but I can wire another external bridge. :shock:
Jeff wrote:Is there any relation/point with the HxC Floppy Emulator ?
Hi Jeff, I'm sorry. Perhaps my questions are not in the right forum, but this is the only forum about an installation of a floppy emulator in a keyboard Technics Kn2000. :(
Roccochiarelli
Re: Technics KN 2000 emulator Gotek
Post by Roccochiarelli »
hi to all, I resurrected this tread after a long time, I also have a kn2000 and I bought, to modernize, the emulator of the Gotek SFRM72TU100K, with the jumper only on S1, and, the belt https://www.ebay.it /itm/Technics-KN-2000-KN2000-Floppy-Belt-Matsushita-EME-213KR-Emulator/302893458305?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649, I used the program to partition a 4 usb stick G, I inserted midi songs on two virtual disks but my kn2000 does not want to read them or open the disk. It gives me the same error that gives a rdoctor, can you help me? thank you
Roccochiarelli wrote: Thu Oct 25, 2018 10:13 pm hi to all, I resurrected this tread after a long time, I also have a kn2000 and I bought, to modernize, the emulator of the Gotek SFRM72TU100K, with the jumper only on S1, and, the belt https://www.ebay.it /itm/Technics-KN-2000-KN2000-Floppy-Belt-Matsushita-EME-213KR-Emulator/302893458305?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649, I used the program to partition a 4 usb stick G, I inserted midi songs on two virtual disks but my kn2000 does not want to read them or open the disk. It gives me the same error that gives a rdoctor, can you help me? thank you
Have you the HxC firmware ? :
https://hxc2001.com/store
Roccochiarelli
No, I do not have the hxC firmware, the one I have is only the Gotek and the emulator and I do not even know how to use it, but if you explain it and this helps me to solve my problem I can ask where to buy it, thanks. What is the purpose of this firmware?
Roccochiarelli wrote: Thu Oct 25, 2018 11:18 pm No, I do not have the hxC firmware, the one I have is only the Gotek and the emulator and I do not even know how to use it, but if you explain it and this helps me to solve my problem I can ask where to buy it, thanks. What is the purpose of this firmware?
The purpose is to replace the original firmware. the HxC firmware offer better compatibility.
We don't provide support if you don't have the HxC Firmware into the emulator.
Roccochiarelli
Hi , with this firmware is secure for resolve my difficult?
yes sure.
Roccochiarelli
sorry but my emulator is sfr1m44, and not sfrm72
Roccochiarelli wrote: Tue Oct 30, 2018 8:22 pm sorry but my emulator is sfr1m44, and not sfrm72
not a problem for the hxc firmware.
Roccochiarelli
ok , where I can buy it? but I need instruction , help me please
Roccochiarelli wrote: Fri Nov 02, 2018 10:28 pm ok , where I can buy it? but I need instruction , help me please
there : https://hxc2001.com/store
