Enterprise 64 / 128 supported
Re: Enterprise 64 / 128 supported
mhh lots of questions. i will try to update the documentation soon.
Finally one new function proposal:
Save the last used directory to the CFG file, for example at 0x0280/0x02C0 similar as the selected images.
will check this!
About the Pin02/Pin34 settings, which Disk Change methods can be emulated?
It is possible emulate the old Sony method where the Disk Change signal reseted by Pin01?
No the pin01 is connected to the gnd on the actual hardware.
but there is some workaround solutions to avoid this problem.
Zozosoft
Post by Zozosoft »
Jeff wrote:mhh lots of questions. i will try to update the documentation soon.
Zozosoft
Post by Zozosoft »
Jeff wrote:i will try to update the documentation soon.
Any news?
Zozosoft
Post by Zozosoft »
Yesterday at Hungarian Sinclair&Enterprise Club day HxC used with Enterprise. On this occasion I made ROM version of the HxC Manager.
:D
Zozosoft
Post by Zozosoft »
