Kawai Q80
Re: Kawai Q80
Are you using the original floppy ribbon ?
javierdonu
Re: Kawai Q80
Post by javierdonu »
Ive try with the original before put the HxC into the Q80 and same result. But for mounting the HxC into Q80 i needed a floppy ribbon largest cause is not the same like the floppy drive.
The question is: Must I put in On another switch from HxC as the number 1?
Javier
Re: Kawai Q80
javierdonu wrote: Wed Jul 18, 2018 8:55 am Ive try with the original before put the HxC into the Q80 and same result. But for mounting the HxC into Q80 i needed a floppy ribbon largest cause is not the same like the floppy drive.
Javier
Try ID0-A (1) + ID3-A (4)
javierdonu
Re: Kawai Q80
I`ll try
thanks
javierdonu
Re: Kawai Q80
Bad news. I change numbers 1 and 4. And again I can format but when im going to save my own song ..."disk unavailable ". Externe is that after format, there are again the DR-550II and the others files I said before. :-(
I really don't understand :-(
Any Q80 Owner who read this may can help me .
Thanks Jeff
Javier
Re: Kawai Q80
Is the original floppy drive working properly ?
javierdonu
Re: Kawai Q80
I bought HxC because the floppy drive crashes.
Re: Kawai Q80
javierdonu wrote: Wed Jul 18, 2018 8:20 pm I bought HxC because the floppy drive crashes.
What was the problem exactly ?
javierdonu
Re: Kawai Q80
Floppy drive does not recognized any floppy disk. NO format. NO read...
so I decide change for your product... Now, Format, delete, save and load function , works but... with the problems I said you.
Im lost! hahaha
Re: Kawai Q80
javierdonu wrote: Thu Jul 19, 2018 8:57 am Floppy drive does not recognized any floppy disk. NO format. NO read...
Im lost! hahaha
Maybe that the floppy drive problem wasn't directly related to the drive itself.
With these 20/30 years old machines, capacitors are becoming more and more prone to failure and the power supplies issues are more and more present with some "funny"/hard to diagnose behaviours. There are already some examples on this forum. That's why i am asking about the old drive.
Have you another machine to test the HxC drive ? (PC or anything else ?)
javierdonu
Re: Kawai Q80
No :-(
Q80 was the only machine with floppy (now HxC).
It was another reason to change it.
javierdonu
Re: Kawai Q80
Good News!!!
I've changed pin direction in the floppy ribbon and it works!!!
I can format, save my own file, load and delete it :-)
Thanks for your patience.
Another question is... Can I read and export to my computer these files (what are into the DSKA000x.HFE)?
Thanks again !!!
Javier
Re: Kawai Q80
javierdonu wrote: Fri Jul 20, 2018 12:13 pm Good News!!!
Thanks again !!!
Javier
What ? You mean the floppy ribbon direction ? This floppy ribbon is twisted ?
javierdonu
Re: Kawai Q80
Yes. The floppy ribbon was one conector to motherboard and two connectors to Floppy emulator. In the begginingI used the the final connector who was a little twisted . But i changed and I used the middle conector ... and it works. So, was the twisted cable.
And...Please. Can I read the content in a .HFE file? I would like to save Midi files from Q80 directly in my computer, reading the SD card
Thanks again.
Javier
Re: Kawai Q80
javierdonu wrote: Fri Jul 20, 2018 2:23 pm Yes. The floppy ribbon was one conector to motherboard and two connectors to Floppy emulator. In the begginingI used the the final connector who was a little twisted . But i changed and I used the middle conector ... and it works. So, was the twisted cable.
ok got it. Yes this explain the issue.
Thanks again.
Javier
Is this machine supporting DOS/FAT12 floppies ?
