2.8" QD Disk Emulation
Re: 2.8" QD Disk Emulation
hoby wrote: Tue Sep 10, 2019 8:39 pm I get the "bad data.." when trying to load
try to read the patch2 file and write something to blank.qd and post it back here.
EDIT : test.zip removed.
hoby
Post by hoby »
I could not read the patch2 file.
I loaded the Old flute sound and saved it to the blank file. Looks like it saved alright, but i could not load it again
EDIT : WrittenToBlank.zip removed.
update to the attached firmware and write to the attached blank.qd and post it here.
EDIT : test2.zip removed.
hoby
Post by hoby »
OK - update to 3.4.6.5a and saved to blank disk. No load after save.
EDIT : blank.QD.zip removed.
New blank qd & fw to test !
EDIT : test3.zip removed.
hoby
Post by hoby »
Hmm, Akai still not happy :)
Her is the saved file
hoby wrote: Tue Sep 10, 2019 10:44 pm Hmm, Akai still not happy :)
the crc is valid. What if you try to read the image ?
hoby
Post by hoby »
Sorry - it was no problem saving the file, but I could not load or verify after saving without getting the bad data error.
hoby wrote: Tue Sep 10, 2019 11:08 pm Sorry - it was no problem saving the file, but I could not load or verify after saving without getting the bad data error.
Have you the usb serial cable ? It will be time to use it to see some debug output.
hoby
Post by hoby »
I have the USB serial. I am on a mac at home, so I can give it a shot tomorrow.
hoby wrote: Tue Sep 10, 2019 11:35 pm I have the USB serial. I am on a mac at home, so I can give it a shot tomorrow.
Have you a terminal software ?
and another fw & blank file to test.
test3.zip
(61.57 KiB) Downloaded 3185 times
hoby
Post by hoby »
Thanks. I'll try it this afternoon.
Must admit, I have not played around too much with terminal SW. Is there any specific program you would recommend I should look into?
hoby wrote: Wed Sep 11, 2019 9:30 am Thanks. I'll try it this afternoon.
For the moment just try the above firmware.
I have added the S700 format into the HxC QD tool kit software. It is now able to check the data and convert the S700 QD images to wav.
Is the attached wav file sound like to what you have recorded yesterday ?
sample.wav.zip
(38.74 KiB) Downloaded 3897 times
hoby
Post by hoby »
Jeff wrote: Wed Sep 11, 2019 12:11 pm
sample.wav.zip
hah - yes it does, it is just me scratching the surface of the x7000 with a contact mic, to the input. I'll try do something more exiting next time.
