Firmware update ! :
17 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.20.1a
- USB Direct Access mode code refactored :
-----> Read/write performance increased (hxcmount).
-----> Command/Write indications printed on the LCD.
- USB access cache : Write timeout value set to 2 seconds.
@tzok : hxcmount write issue fixed !
tzok wrote: Fri Mar 16, 2018 12:56 pm So creating a FAT16 partition on the USB-stick should solve most of the problems...
Yes maybe. Is the ST FAT16 100% compatible with the DOS version ? If so this worth a try ;)
tzok
Post by tzok »
Without driver, there is a limit of sector size 1024B, resulting in max. partition size of 32MB. But there are solutions to overcome this problem:
http://atari.8bitchip.info/ASThdFAQ.html
http://atari.8bitchip.info/atdoscp.html
http://info-coach.fr/atari/documents/_m ... _v1.1b.pdf
Actually there are HDD drivers that support FAT32, so this is also possible.
Vaklin
Post by Vaklin »
:D
Firmware update ! :
18 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.1a
- Indexed mode : Ignore file extension. You can now use any file extension
as long as the file is supported by the floppy emulation engine.
(Can be DSKA0000.HFE/IMG/DSK/ADF/ADL...)
- Acorn machines (*.ADL, *.ADM, *.ADF):
Sectors gap, interleave and tracks skew aligned to the real machine.
Software update ! :
18 March 2018: HxCFloppyEmulator 2.1.9.1
-> Acorn BBC file format loader (*.ADL/ADM/ADF) fixed.
18 March 2018: HxCFloppyEmulator 2.1.9.0
New XML format definitions :
- Acorn ADFS (160K).
- Acorn ADFM (320K).
- Acorn ADFL (640K).
- Dynacord Add-one.
Stream importer :
- More debug/error messages,
- unconventional index period support.
https://hxc2001.com/download/floppy_driv ... r_soft.zip
Firmware update ! :
19 March 2018: Firmware STM32 USB HxCFloppyEmulator v3.1.21.2a
- USB Direct Access mode code : Index gap increased
(Amiga File selector & HxC copy utility under WB fix)
rfancella
Post by rfancella »
So, I have a question. I recently added an OLED display and rotary encoder with a button built in to my Gotek. I plan on mounting it under my existing floppy drive on my Amiga 1200. With just the rotary encoder accessible, how would one update firmware? Without have up/down buttons to press?
Thanks so much!
Ron
rfancella wrote: Wed Mar 21, 2018 4:36 pm So, I have a question. I recently added an OLED display and rotary encoder with a button built in to my Gotek. I plan on mounting it under my existing floppy drive on my Amiga 1200. With just the rotary encoder accessible, how would one update firmware? Without have up/down buttons to press?
Thanks so much!
Ron
this is not supported by the bootloader, but i can probably add an "update" entry in the internal menu ! :)
rfancella
Post by rfancella »
Jeff,
Thank you for your response. That would be ideal. :D
Ron
Vaklin
Post by Vaklin »
Hi Jeff!
Is "READY signal from FDD necessary to provide a proper work of HxC floppy emulator software?
I'm playing with one 8" floppy, and better is to know in advance. This one doesn't provide native this signal.
Vaklin wrote: Thu Mar 29, 2018 8:59 am Hi Jeff!
for the emulator itself, no, but the target machine may need it.
Vaklin
Post by Vaklin »
The target machine is another story.
Thank you for the answer!
tzok
Post by tzok »
I wanted to answer you a long time ago - same as Jeff did, but I've realized you're asking for something different. If I understand you right, you want to use HxC Software to make an image of a physical disk in a vintage disk drive connected to the PC. Am I right? Ready signal is an output from the drive, so if target system doesn't use it, it woudn't matter if the emulator provides it or not.
Vaklin
Post by Vaklin »
I'm asking is software, which makes images, wants "ready" signal. I hope Jeff answered me about that.
