Commande 20 Cartes HxC version USB MAJ[03/05/2008] FINI
rofl0r wrote:giants, i am trying to get some ppl here to assemble one hxc (usb) for me.
but the description of the parts needed on the hxc website is very lousy.
i.e. L1 is described as "ferrite" (no details ?? -how can one find that with that dexcription), i was not able to find a single one of the condensateurs on the catalogue of big electronic shops (i.e. segor.de, rs-components.at ), Y2 is also not to be identified, as well as the J50 - J63.
the voltage of the LEDs is not known as well.
if i could succeed getting all the required detailed information i could possibly invest a lil money to get around 20 hxc's done so the costs will be smaller.
forget L1, replace it by a wire.
Y2 -> 16Mhz oscillator
J50-J63 : straps (wire)
leds are 3mm led
if you want made a small batch (>5 units) don't use the pcb on the website, there are an another one which is better (Giants used it to make its batch).
Where are you come from ?
rofl0r
Post by rofl0r »
Jeff wrote: forget L1, replace it by a wire.
leds are 3mm led
i am from austria (autriche).
what other pcb is to recommend ?
thanks!
rofl0r wrote: i am from austria (autriche).
thanks!
this one:
http://sasfepu78.free.fr/images/Final_HxC_TOP_lowQ.jpg
http://sasfepu78.free.fr/images/Final_HxC_BOT_lowQ.jpg
rofl0r
Post by rofl0r »
hmm, the altera chip seems to be the same ?
it is the one that costs 18.18 eur on segor.de if 10 pcs are ordered.
may i ask for the print layout that is required to make the board (like the file https://hxc2001.com/floppy_drive_emulat ... ULATOR.pdf ) for this new rev. c ?
and maybe also a part list (if something else has changed).
i will make an update on the webpage with the new pcb and the part list.
Parano-Sprite
Post by Parano-Sprite »
Salut Rhod et Magiceyes,
magiceyes wrote:
Rhod wrote:yo, reçu, mais j'en ai reçu 2 au lieu d'une 8)
Rhod t'es trop fort ! En tout cas merci, tu nous enlèves une sacrée épine du pied :D
Rhod : J'ai bien recus le colis, pas de soucis et je te remercie encore, c'est vraiment nickel. ;)
Je vois aussi que tu as recu le payement pour les frais de port, donc, pour ce qui te concerne, c'est fini ... ;)
Magiceyes : A nous maintenant ...
Je viens de faire le colis pour te l'envoyer, mais je n'aurais pas le temps de le mettre à la poste ce matin. Je te l'envoi Lundi sans faute, je te tien au courant dès qu'il est envoyé, pour te donner le N° de colissimo. ;)
@+ tout le monde et bon Week-end.
Gerard
rofl0r
Post by rofl0r »
Jeff wrote: i will make an update on the webpage with the new pcb and the part list.
great, i can't wait starting to create the first boards ;)
magiceyes
Post by magiceyes »
Pas de pb Parano-Sprite, je ne suis pas pressé d'autant que j'en ai déjà une et que j'attends la version libre du logiciel de Jeff. Tant que je sais où elle est c'est bon ^^.
chiourme
Post by chiourme »
Je vends une carte 80€, car je n'ai finalement pas l'utilité d'en posséder 2.
Si ca interesse quelqu'un.
VENDU!
gazeux_snake
Post by gazeux_snake »
Je serais bien intéressé^^
rofl0r
Post by rofl0r »
gazeux_snake wrote:Je serais bien intéressé^^
too late, l'argent est envoyé
Blackstar
Post by Blackstar »
Salut !!
Bon, je me tate aussi pour ma deuxième carte. En bricolant un peu les ordis, on arrive toujours à faire dépasser une petite nappe 3,5 pouces, donc....
Si qqu'un est interessé pour le prix standard de 80 euros...
Voilà @+
Longshot
Post by Longshot »
J'ai testé la mienne et elle fonctionne parfaitement sur un cpc 6128. 8)
Même avec la démo "midline process" qui décompresse des images et joue de la musique pendant le chargement.
Merci et bravo pour ce beau boulot.
Petit détail. La nappe du cpc 6128 part du drive B, mais bien qu'il y ait un inverseur de drive (il est vu comme un A par le 6128), je suis obligé de sélectionner DS1 pour que ça marche.
Le jour ou vous faites une série sdcard, va falloir viser plus haut que 20 cartes à mon avis :lol:
Rhaaaa!
Giants92
Post by Giants92 »
Yup,
Bein le probleme c'est que c'est du Taf MORTEL.
je te donnes les gros points négatifs que j'ai retenue !
- Avoir les 20 personnes rapidement
entre les personnes qui change d'avis, les personnes qui ne repondent pas au mails et ceux qui répondent... un peut tard.
On a perdu du temps, les prix ont donc changé et de beaucoup.
- Le soudage.... honnêtement, C'est LA MISERE a souder autant de cms
Je crois que j'en ai jamais soudé au temps de toute ma chienne de vie :)
J'ai meme fait participer ma mere (que j'abrite en ce moment) et ma femme, pour dire.
Deja 20 ca fait du boulots monstre au niveau soudage,
Regarde, pour ceux qui ont deja soudé vont me dire, y'a pas grand
chose... oui mais pas grand choses multiplier par 2 faces multiplier par 20
Plus des micro-soudure comme le controleur USB ou faut pas se louper
et des trucs long a souder (84 pins x 20) pour le sup. PLCC
Faut vraiment avoir la foi, j'te ld'is :)
Niveau tune, ca ne m'a pas rapporté grand chose
(les prix ont changé et les taxes d'envoie aussi)
Resultat, faut vraiment avoir la foi :=))
Pour moi, attendez un peut que je me remette :)
___________
Giants92 wrote:Yup,
C'est pour cela que je suis plutôt pour le DIY (ou FLETM en français ;-) ).
Il est clair qu'il faut avoir la foi pour une fab série (CMS ou pas d'ailleurs).
Tu remarqueras qu'il y a très peu de projet sur le net qui sont finalement fabriqués en petite série, pour les raisons que tu as invoquées.
