Tobias909 wrote: Tue Jun 18, 2019 10:51 pm yes, those 4 files are on the card. I exactly copied them to the SD Card.
Try to reset the emulator parameters. remove the sdcard , press select, choose "clear eeprom" -> yes.
Tobias909
Post by Tobias909 »
Thank you, but it doesnt work.
Well, I formatted the SD Card on a mac... but formatted as FAT.
I wanted to try that again on a windows-PC...
Dont know if that is a case, MacOSX always puts some hidden folders on it.
Perhaps Windows doesnt...
Or my FZ1 isnt working right.
Tobias909 wrote: Mon Jun 24, 2019 2:06 pm Thank you, but it doesnt work.
Is the FZ1 trying to read the emulator ? do you see something change on the emulator when you try to read ?
marfemarf
Post by marfemarf »
I installed the emulator. Sd version, on my FZ. Works great. I plopped the files from the zip onto the sd card.
I can seem to load some banks. They have a few sounds on them from the zip file?
I tried for the first time to actually sample but I get a memory full. That is with a bank loaded. I can't sample anything without it loaded. Do I need a bunch of blank fz files on the SD card to load up to add samples to? Like memory slots? Or virtual blank floppies? Thanks
marfemarf
Post by marfemarf »
basically. Turn the FZ-1 on. How do I sample and then save the file?
im using a REV F sd
marfemarf
Post by marfemarf »
I would try and redo this on a pc. I have a Mac but chose to use a pc with sd card slot to do this. It worked for me. .
marfemarf
Post by marfemarf »
Theres all kinds of instructions on how to load a floppy image or convert one. But I don't see anything on how to sample directly on the sampler and save the file. Without a computer. How do I do this? Is anyone out there? Help, SOS Thanks. :(
marfemarf wrote: Wed Jul 17, 2019 10:13 pm Theres all kinds of instructions on how to load a floppy image or convert one. But I don't see anything on how to sample directly on the sampler and save the file. Without a computer. How do I do this? Is anyone out there? Help, SOS Thanks. :(
Not sure if this question is directly related to the hxc emulator but you may need to check the Casio FZ-1 user manual.
The SD HxC Floppy Emulator work as a floppy disk drive. just copy/past some blank casio hfe file on the sdcard.
marfemarf
Post by marfemarf »
Well, that is an important piece of information. I need blank hfe files in the sd card. Where do I find those? Thanks!!
marfemarf wrote: Thu Jul 18, 2019 7:04 pm Well, that is an important piece of information. I need blank hfe files in the sd card. Where do I find those? Thanks!!
I think that this should help you :
marfemarf
Post by marfemarf »
I already added those files to the sd card. It works, but I don't see a bunch of blank hfe files, though. Isn't that what I need on the card to sample and save on the FZ?
marfemarf wrote: Sat Jul 20, 2019 10:33 pm I already added those files to the sd card. It works, but I don't see a bunch of blank hfe files, though. Isn't that what I need on the card to sample and save on the FZ?
Try to format one of these files and then just duplicate the hfe file on the sdcard.
marfemarf
Post by marfemarf »
sorry to be so thick. I am using an OSX Mac. How would I format the hfe file? Basically make a Bunch of blank hfe files. ?? Thanks for the help
marfemarf
Post by marfemarf »
What is the format? right click what file in the card and choose what formatting? How do I format an hfe file? HELP SOS
marfemarf
Post by marfemarf »
anyone?
