EPSm rack mount
lotharek
Re: EPSm rack mount
Post by lotharek »
first of all - every user of cased version MUST REMEMBER that jumper pins are reversed - i mean upside down !!!
so, pins confirgation mu be be done according to this picture :
pins IN CASED VERSION to fitt in cased are angled, so according to offcial manual the order stays the same, but drives A-B are switched.
SD CASED.JPG (43.97 KiB) Viewed 4154 times
..... Atari Roxxx !!!
lotharek
Re: EPSm rack mount
Post by lotharek »
Do You have Your sd emul SET ID0 drive B ? floppy cable is not inverted
ps. please, post it back for test/ replacement.
sPrause
Re: EPSm rack mount
Post by sPrause »
Regrets on the long late reply. I had received the replaced HxC SD emulators from Lotharek. The problem has been completely resolved! It must have been a hardware (or firmware) issue. The steps for setting up configuration and the floppy images worked just fine, as previously described. This really is a great product to keep life up for old floppy products, and being able to manage floppy images in the future. My thanks to Lotharek for great customer support, and handling shipping charges. Also thanks to "jeffe" in helping me test and verify problems with his EPS. You guys are very helpful and considerate. I have lots of EPS working floppy images that can be traded with other Ensoniq users. Later...
