Casio Celviano AL-100R/Al-150R Digitalpiano and SDCard HxC
BCMach
Re: Casio Celviano AL-100R/Al-150R Digitalpiano and SDCard H
Post by BCMach »
hello! i can´t convert the ".ima" file i created the file with the winmage and can´t convert with the program HxC Software! can you help me using Hxc software??
BCMach wrote:hello! i can´t convert the ".ima" file i created the file with the winmage and can´t convert with the program HxC Software! can you help me using Hxc software??
just drag & drop the ima/imz file on the hxc window and do an export.
that's all
what is the problem exactly?
bob001
Post by bob001 »
is there any chance to get (native) write support for Casio Celviano AL100R with the new Software 2.0.12.2? Is there also already support for long file names?
Thank you
Robert
bob001 wrote:Hi Jeff,
Thank you
Robert
mhhh i don't understand. What do you call "native" write support ? do you mean at the casio ?
EDIT : Yes long name support is now active.
EDIT2 : There is a new firmware allowing a low level format. If you want try it, this is in your email box.
bob001
Post by bob001 »
Thank you Jeff. I'll try it...
Best Regards
Robert
bob001
Post by bob001 »
saving data to an empty 720K Image created with HxC Software now works! That means there is also no more 3rd Party SW necessary! 1,44 Mb Images still don't. But that doesn't matter. 720K are enough in all circumstances of this device. Thank you for your excellent support!!
Best Regards
Robert
javiaris
Post by javiaris »
Hi, I also have the Casio AL 100R digital piano. I've installed the Rev F HxC Floppy emulator and tried formatting images at 1,44MB and 720KB formats but the piano keeps on saying "Error! Disk Format". Can you help me setting this to work?
Many thanks
Groundcrew
Re: Casio Celviano AL-100R/Al-150R Digitalpiano and SDCard HxC
Post by Groundcrew »
I have the same problem like Javiaris: "Error! Disk Format".
In this topic there was no answer to his and my problem...
Hopefully anybody can help solving this problem!
Thanks and best regards, Groundcrew
Groundcrew wrote: Wed Feb 01, 2023 1:30 am Hello,
Which emulator are you using ?
Groundcrew
On the Oled display the version 3.38 is displayed when I turn on my Casio..
When I put the USB stick into the Gotek it shows Error 34.
I think the problem is to use the correct format for the USB stick. I have tried the 720K as well as the 1.44M format with USB Floppy manager 1.4. But still the same result :-(
Or may be the problem ist to convert the discette *.cma (Leuchttastenschule) files to *.img files?
What is the exact procedure for that?
Or could it be that the Jumpers on the Gotek are not correctly set? They shorten S1 and JC.
Thanks very much for your help!
Groundcrew
I have managed that the Gotek accepted the USB stick and is showing the different *.img files.
If I select one of them, the busy LED is on and after a while my keyboard is showing "Error! Disk Format".
I think is has to do with the 720k format. My image files have 1,44M.
But I have no idea how to change the image files to 720K format :-(
Groundcrew
Finally!!!
I have managed to convert all my disks to the USB-stick using the HxCFloppyEmulator v2.5.6.6.
You have to use the button "Disk Browser" and just put in the intended *.cma file.
Yue can choose as save/export either *.img or *.hfe. Both formats are working well on a stick.
Just save the files on a USB-stick into the root directory. The stick needs to be formatted with Fat32 first.
That`s all :-)
