Floppy Emulator Manager not working
scarforlife
Re: Floppy Emulator Manager not working
Post by scarforlife »
I still can't put it to work :(
scarforlife wrote:I still can't put it to work :(
Please show me your jumper setting...
scarforlife
I can't get a good picture but it's like this (cased version) and with the jumper on drive A
scarforlife wrote:I can't get a good picture but it's like this (cased version) and with the jumper on drive A
Where is the upside of the box on this picture ?
(And where is the jumper ?)
scarforlife
Here, I think you can see it better now
scarforlife wrote:Here, I think you can see it better now
Ok So the previous picture is wrong ;-)
As i suspected , you are actually on the ID3/MTRON line.
Just move the jumper to the opposite side (upside left.)
When you look the rear of the floppy emulator the jumper setting is :
----Upside-----
<A><A><A><A>
ID0-ID1-ID2-ID3
<B><B><B><B>
--Down side----
Just place the jumper at the position <A>-ID0
scarforlife
oh my... :roll:
thank you thank you thank you! it works, I can see the files now but I can't display the HELP section and I don't know how to select a file (up & down). I've tried the mouse, keyboard, joystick and I can't move the cursor... :|
scarforlife wrote:oh my... :roll:
Actually the keyboard is used. Try to play with the arrows of the keyboard.
scarforlife
it doesn't work with the cursors. i can use F1, F2 etc..., i can search for a specific games but i can't select a file with the cursor :x
scarforlife wrote:it doesn't work with the cursors. i can use F1, F2 etc..., i can search for a specific games but i can't select a file with the cursor :x
mhh ? which amiga have you ?
It's a QWERTY keyboard ?
scarforlife
Amiga 500 with qwerty keyboard...
scarforlife wrote:Amiga 500 with qwerty keyboard...
NTSC or PAL ?
Just for test : try to disconnect the mouse and the joystick.
scarforlife
it's PAL version. I've disconnected both (mouse & joystick) and still the cursor keys don't work.
scarforlife wrote:it's PAL version. I've disconnected both (mouse & joystick) and still the cursor keys don't work.
It should ...
make me an screenshot please.
