Yamaha VL1 floppy drive - different kind of connector
glenn.szymanski
Re: Yamaha VL1 floppy drive - different kind of connector
Post by glenn.szymanski »
CoolColJ wrote:
This one will on OSX
http://www-acad.sheridanc.on.ca/~degazi ... esign.html
What I did was get the drive, dump all my patches to Vl1 and then to Sounddiver and use that instead
CoolColJ wrote:
I don't think it's my browser, I tried Safari and Firefox, but I don't think that OSX one is still there, I get this message when I click it...
The requested URL /~degazio/AboutMeFolder/SoftwareDesign/VL ONE70 ReadMe.txt was not found on this server.
I emailed the guy, but who knows if I'll hear back.
Is sounddiver only available in OS 9?
CoolColJ
Post by CoolColJ »
Links are broken
Soundiver is available on Windows and OSX - can't buy it anymore.
Since the VL1 can do manual sysex dumps, you can just use an sysex recording software and save the dumps to a file.
And manually dump back to the Vl1, either as a bank or patch
glenn.szymanski
Where can I find Sounddiver for OSX?
I've never worked with sysex messages before (all i know is that it means system exclusive), I use Logic Pro 9 on a Macbook Pro running OS 10.6.4. Can I use Logic to do this?
Are the voice and bank files on Ken Barry's archive considered sysex files?
I also saw this program...
http://www.snoize.com/SysExLibrarian/
CoolColJ
Post by CoolColJ »
Google?
I'm a windows guy so I don't know anything about OSX, but Soundiver has not been developed in years and Emagic was bought out by Apple and Soundiver was dumped.
Don't know Logic, but it should be able to do it, but your better off with a dedicated program for simplicity
All those files on Ken Barry's site are native VL1 files, so you can't read them as sysex.
You either copy them to a PC formated floppy disk and put it into the VL1 drive and read it
or load it into the Yamaha software or that OSX program and send it as sysex to the VL1
johndoes
Post by johndoes »
I hope I post in the right section. I want to replace my dead FD drive in my Yamaha VL7... and Jeff link from 1st page of this thread take me to a page shows "Plik obrazu nie istnieje". Can I find and buy a drive emulator or better, a 34 to 26 adapter in order to use an ordinary drive in my synth? I even bought a new belt for the old drive, it didn't worked....Thanks in advance!
johndoes wrote:I hope I post in the right section. I want to replace my dead FD drive in my Yamaha VL7... and Jeff link from 1st page of this thread take me to a page shows "Plik obrazu nie istnieje". Can I find and buy a drive emulator or better, a 34 to 26 adapter in order to use an ordinary drive in my synth? I even bought a new belt for the old drive, it didn't worked....Thanks in advance!
https://lotharek.pl/productdetail.php?id=39
It use a 1mm connection spacing on the flex. Just make sure that this is the same on the VL7
johndoes
Post by johndoes »
Thanks for quick response :) So no chance for adapter only? (the price is similar with a new replacement floppy drive, not sure if I'm ready to invest in such an old synth). VL7 had absolutely the same parts as VL1, that's why I posted here.
mshakeshaft
Post by mshakeshaft »
Did anyone ever get this to work? I have a Yamaha VL1-M and the floppy has finally given up. It is probably just a case of replacing the rubber band this this seems a more permanent solution.
Martin
CoolColJ
Post by CoolColJ »
mshakeshaft wrote:Did anyone ever get this to work? I have a Yamaha VL1-M and the floppy has finally given up. It is probably just a case of replacing the rubber band this this seems a more permanent solution.
Martin
I just ended up buying a beltless replacement floppy drive from Ebay....
The person selling them basically retrofitted a a different connetor board on it.
I suppose you could just use a similar thing on this and other Flash to Floppy devices
captain.cookie
Post by captain.cookie »
Jeff wrote: Sun Mar 09, 2014 9:20 am https://lotharek.pl/productdetail.php?id=39
Above URL is not working but anyhow, the spacing on the flex is not 1mm but a non-standard 1.25mm, therefore you'll need a 26 to 34 pin adaptor you can find on ebay.
Gotek reference : SFR1M44-DU26 will NOT work as well.
Fred
adamsal
Post by adamsal »
Jeff wrote: Fri Apr 29, 2011 10:53 am So the shematic of the adapter should be :
This schema contains an error!
All pins on the 26 pin ribbon are reversed.
The power is at 1, 3, 5.
Yamaha VL1M.gif (30.54 KiB) Viewed 9034 times
adamsal wrote: Thu Apr 22, 2021 8:06 pm
possible. i used this post to make it : viewtopic.php?p=4135#p4135
