Problem with msdos image
mau_rizio wrote:Don't work.
Perhapse is there a tool i can use to give you info about the sd card?
Soldering the 1,8kohm resistor would work?
Or i can send you the card, i you will send it back after the work :)
The 720KB floppy image doesn't work ?
mau_rizio
Post by mau_rizio »
No, it doesn't work.
Sometimes after a long time reading track 0, the hxc shows "choose a file" like the image wasn't selected.
On Rev B or C ?
Can you try to reformat the sdcard ?
mau_rizio
Post by mau_rizio »
mau_rizio wrote:
Jeff wrote: The 720KB floppy image doesn't work ?
On Rev B or C ?
Rev C
Yes, many times.
I used SDFormatter 2.9.0.5 taken from sdcard.org
mau_rizio wrote:
mau_rizio wrote: No, it doesn't work.
On Rev B or C ?
Rev C
Yes, many times.
Formatted in FAT32 ?
Can measure the 5V power supply ?
Can you retry the emulator on another system ?
mau_rizio
Post by mau_rizio »
mau_rizio wrote:
Jeff wrote: On Rev B or C ?
Rev C
Yes, many times.
Yes
I'm not so good with this things, but if you tell me wich point to test i will try.
I'm taking power from the pc and the original disk drive is working well.
This is the second pc i'm testing, the first has ms-dos the second windows xp, same problem on both pc.
Tomorrow i will test on amiga and msx.
mau_rizio wrote:
mau_rizio wrote: Rev C
Yes, many times.
Yes
Have you tried the 720KB image on another sdcard?
mau_rizio
Post by mau_rizio »
Yes, it's working good on a 128mb card and on a 1gb card.
mau_rizio
Post by mau_rizio »
Tested on other 2 pc, one with msdos and one with win98, same errors.
I confirm that it's working ok on msx and amiga.
mau_rizio wrote:Tested on other 2 pc, one with msdos and one with win98, same errors.
Try this new firmware:
https://hxc2001.com/floppy_drive_emulat ... 3_1_0B.UPD
mau_rizio
Post by mau_rizio »
Now the error message under winxp is different "Insert a disk in drive A:"
The green led makes a lot of little blinkings, if i use another sd card the led dosn't blink.
mau_rizio wrote:Now the error message under winxp is different "Insert a disk in drive A:"
What is the jumper setting and cable used ?
mau_rizio
Post by mau_rizio »
ID1 using a stardard pc floppy cable, those with 2 connectors for drive a and b
mau_rizio wrote:ID1 using a stardard pc floppy cable, those with 2 connectors for drive a and b
Twisted or not twisted ?
If non-twisted floppy cable:
A: -> ID2
B: -> ID1
If twisted floppy cable:
A: -> ID1
B: -> ID2
