AKAI FD235HF A700 Hell!
Re: AKAI FD235HF A700 Hell!
Horizonsound wrote: Tue Feb 21, 2023 3:00 am Interesting now, it looks like it is trying to read. The Track indicator goes from 000 to 001 very quickly before the error occurs.
This is with the non-gated firmware installed.
https://youtu.be/1jJhQzPiFwQ
Anthony.
ok then now you need to try different interface mode settings.
Horizonsound wrote: Mon Feb 20, 2023 11:53 pm Hi Jeff,
Yes the disks are HD and DOS compatible.
To be sure I imported an existing data disk into HXC (see below)
MFM HD 500kbps 80 Tracks.
I then saved as a .hfe file, so it should load straight away.
The access LED lights up, but can't be read.
Anthony.
Can you share / send me this hfe ?
Try to read all the attached files and let me know which one is working.
totest.zip
(219.78 KiB) Downloaded 3783 times
Horizonsound
Post by Horizonsound »
Thanks for persisting with this issue Jeff.
I've tried all the .hfe you sent though, but no luck with any of them. Some look like they try to read (Track counter goes up a little then back to 000).
Attached is the .hfe which should be formatted correctly.
When you mentioned that different interface modes need to be tried out, which settings were you meaning?
Is there a possibility it is a hardware / wiring problem that still needs to be resolved?
Anthony.
01 Reel Disk.zip
(135.72 KiB) Downloaded 3654 times
Please :
- Reset any internal parameters with the embedded menu. (clear settings menu)
- Try try the attached files and CFG files.
If this still doesn't work update to the attached firmware and retry.
HxCUSBFE.UPD
(94 KiB) Downloaded 3780 times
totest.7z
(55.09 KiB) Downloaded 3652 times
fertje
Post by fertje »
Hi Anthony,
Did you manage to get this working?
Cheers,
Fertje
