Formatting
Re: Formatting
I think that you can probably find the opcodes sequence but with different jump addresses :
ED42            SBC     HL,BC         .B
DAXXXX          JP      C,XXXXH       .}l	; Motor Fast test
017D00          LD      BC,007DH      .}.
B7              OR      A             .
ED42            SBC     HL,BC         .B
D2XXXX          JP      NC,XXXXH      ..l	; Motor Slow test
3E88            LD      A,88H         >.
32XXXX          LD      (XXXXH),A     2.F
bazzano
Re: Formatting
Post by bazzano »
After alot of investigation I successfully patched FORMAT/CMD command to remove "motor too slow" error, and now formatting works.
Timing speed is software based by comparing a few values, so simply removing the conditional jump made the job.
This is the code I found:
5546 2113f4    ld      hl,0f413h
5549 19        add     hl,de
554a 21685a    ld      hl,5a68h		--> motor too fast
554d d2b256    jp      nc,56b2h
5550 2197f3    ld      hl,0f397h
5553 19        add     hl,de
5554 218e5a    ld      hl,5a8eh		--> motor too slow
5557 dab256    jp      c,56b2h		--> CHANGE THIS TO NOP-NOP-NOP TO PATCH <--
555a c9        ret
This fix is related to NEZ80 with NE-DOS version G.1.0. I don't know if it's similar to NEWDOS 2.1, but maybe. I'll need to check it.
Now I need to fix the COPY command that has the same problem when copying an entire floppy: infact it makes a formatting at the start, and it returns the same error.
Thank you.
Roberto
Audronic
Re: Formatting
Post by Audronic »
Hi Bazzano
Well done nearly there.
Can you copy individual files ?
Keep going almost there.
There is a good site Italian I think may be interested in you Patch(s)
Ray
If it ain't Broke then PLEASE DONT fix it.
Procrastinators Unite !
Re: Formatting
Well done ! :)
bazzano
Re: Formatting
Post by bazzano »
Audronic wrote: Fri Dec 20, 2019 5:49 am Hi Bazzano
Ray
What site? http://www.z80ne.com ?
It's mine... :-)
Roberto
Audronic
Re: Formatting
Post by Audronic »
Hi Roberto
Yes thats the site.
Then you should be congratulated for such a comprehensive site.
Please keep up the good work.
I have worked with TRS-80s for to long over here in Australia.
Seasons Greetings. Ray
