Roland S-50 Sampler, strange initialising behavior with Gotek
Re: Roland S-50 Sampler, strange initialising behavior with Gotek
agent29 wrote: Sun Apr 28, 2019 8:47 pm What could have caused the image corruption? I created an image using sdisk.exe (roland image program) then loaded it as a raw is this correct or incorrect?
not sure at all.
btw do you know that the hxc firmware for gotek support directly the .out / .img files ?
Just rename them DSKA0000.OUT
(with the latest firmware version you can add something after the name header DSKAXXXX : example -> DSKA0000_my_song.IMG)
agent29
Post by agent29 »
I think ive misunderstood the direct compatibility access with specific image types, I will attempt to access *.out files soon.
The sdiskw.exe I used produced an image with an *s50 extention, (see attachment) can this be renamed to *.out?
s50sys.zip
(32.79 KiB) Downloaded 725 times
agent29 wrote: Sun Apr 28, 2019 9:07 pm I think ive misunderstood the direct compatibility access with specific image types, I will attempt to access *.out files soon.
yes.
agent29
Post by agent29 »
Ive just renamed a s-50 out image downloaded from the internet to DSKA0003.out. (this does work when converted to hfe)
I can load the entire disk into memory providing the OS is already loaded however if I attempt to boot the S50 using that image not ever the display illuminates on the s50 with M0 jumper in situe.
If I Select S0 without M0 the display shows "S-50 system ver, 2,0" but does not boot?
agent29 wrote: Sun Apr 28, 2019 9:34 pm Ive just renamed a s-50 out image downloaded from the internet to DSKA0003.out. (this does work when converted to hfe)
yes some parameters need to be changed for the direct .s50 support.
i will add the direct s50 image support in the next version.
