How to use floppy emulator as external drive B? Possible?
metalages
Re: How to use floppy emulator as external drive B? Possible?
Post by metalages »
Set 1 into $446 if I well remember
metalages
Post by metalages »
Jeff wrote: Fri Feb 26, 2021 1:22 pm
metalages wrote: Fri Feb 26, 2021 9:26 am Do you have news on this topic ? :)
Attached. ( Not tested ;) )
Try it first directly from the GEM desktop since i am not sure about the boot loader.
(Are you expecting to boot from the drive B: anyway ? Is it even possible ?)
It seems to work => selection is done in HXC.
Except when quitting it goes back to gem and then I get 4 bombs.
You got the bombs on the gem or before ?
do you have the bombs with the normal file selector ?
metalages
Post by metalages »
After quitting the selector, the os goes back to gem desktop (without resetting) then after a few seconds the desktop crashes with 4 bombs.
I will not try the regular version as it kills my floppy A drive each time I launch it ;)
Anyway even if desktop crashes, the image selection into HXC seems to be done correctly.
Jerome
Then this may mean that something is not released/restored properly. Will have to check the irq vectors
metalages
Post by metalages »
Do you have any news about integrating this properly in the main version ?
poweredjj
Post by poweredjj »
Is there autoboot version which bootloads properly?
Only prg file starts correctly when using autoboot version posted in this thread.
I tried copying it to a real floppy for fast booting the selector, but it behaves just like unmodified version.
