ERROR: Read ERROR ! fsector 1
sonicthewedge
Re: ERROR: Read ERROR ! fsector 1
Post by sonicthewedge »
Is it the case the the Manager does not alter the date / time of the .CFG file when it writes to it? That would explain why the file does not appear to update.
sonicthewedge wrote: Sat Jul 28, 2018 7:45 am I am only making use of FF-HxC Editor to create the text file to write to the USB .CFG.
I don't support "FF-HxC" at all. I don't know what is this.
sonicthewedge wrote: Sat Jul 28, 2018 7:56 am Is it the case the the Manager does not alter the date / time of the .CFG file when it writes to it? That would explain why the file does not appear to update.
The manager don't update the date/time.
sonicthewedge wrote: Sat Jul 28, 2018 7:45 am Perhaps I have misunderstood the purpose of your application?
Export the current slots to a text file, and reimport them from this text file later.
the operation take some times because the software check the cfg file informations ( image file position on the disk)
Jeff wrote: Sat Jul 28, 2018 8:10 am the operation take some times because the software check the cfg file informations ( image file position on the disk)
And it actually took age because the debug outputs are enabled in the version you are currently testing.
try this one : https://github.com/jfdelnero/HXCFE_file ... r/releases
