HxC @ LINN9000
Re: HxC @ LINN9000
Any HxC is fine for the Linn
Pins match :
LINN 9000 Floppy Pinout :
Pin 1 - /Motor ON       (NC)
Pin 2 - /Sel 0          (HxC Pin 10)
Pin 4 - /Sel 1          (NC)
Pin 6 - Dir             (HxC Pin 18)
Pin 8 - /Step           (HxC Pin 20)
Pin 10 - /Write Data    (HxC Pin 22)
Pin 12 - /Write Gate    (HxC Pin 24)
Pin 14 - /Head Load     (NC)
Pin 16 - /Side          (HxC Pin 32)
Pin 18 - /Index         (HxC Pin 8)
Pin 20 - /Track 00      (HxC Pin 26)
Pin 22 - /Write Protect (HxC Pin 28)
Pin 24 - /Read Data     (HxC Pin 30)
Pin 26 - /Ready         (HxC Pin 34)
synthwalker
Re: HxC @ LINN9000
Post by synthwalker »
Thanks beaucoup Jeff !
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
just a follow up on this thread. I managed the HxC working with my LINN9000 (Forat Mod). But I did not manage to copy the discs onto the HxC. The Blank disc works, but grabbing a real disch via PC don´t. I have no problem with other formats, such as Ensoniq or Roland, but Forat don´t work.
Can you verify that or any idea whats wrong? If you want I could send out a hxc file and a real disc for testing purposis.
What I did meanwhile is a hot swap. Load in the samples via Sony Floppy and then hot swap the cable and save onto the Hxc. Works well but is a lot of work.
Thanks for help,
Cheers
Jürgen
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
- which model should I order ?
- how does it fit with the existing hardware ?
- are there adaptators / 3D printed / other solutions to have a nice fit, as you can find for the SCSI2SD boards ?
- do you have the pin to pin match ? Since there's already a pin converter between the floppy control board and the original Sony drive in the 9000, do you have to plug from the board or from the converter ?
I use a Lotharek SD FB - HXC Rev F BLACK CASE, that fits the old floppy disc construction. It may sits 5mm too far away which dont bother me and also protects the red tactile switches. I did black cover stripes on top and below the SD reader. I also used the pinout from Jeff but let the unconnected wires floating. I crimped a cable myself.
Once you managed to copy files from floppy to SD via a pc and the emulation software, please let me know. Once it works I am willing to share my discs with lot of quality samples. Good luck so far. Its worth it.
Cheers.
Re: HxC @ LINN9000
DrJayWi wrote: Thu Nov 15, 2018 11:37 am Hi Jeff,
Thanks for help,
Cheers
Jürgen
Probably a bitrate/RPM issue. force the bitrate to 500kbits/s into the embedded hxc menu.
Re: HxC @ LINN9000
DrJayWi wrote: Thu Nov 15, 2018 11:47 am Once you managed to copy files from floppy to SD via a pc and the emulation software, please let me know. Once it works I am willing to share my discs with lot of quality samples. Good luck so far. Its worth it.
Cheers.
He now have a working HxC in his LINN9000. Support done some weeks ago by email ;).
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
I still don't get it to work. Emulator still reads way to many bad blocks. What else can I try?
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
Maybe you want me to send you a floppy disk to analyse?
Or anybody can help to convert linn9000 floppy discs to hfe?
Re: HxC @ LINN9000
DrJayWi wrote: Wed Dec 05, 2018 11:59 pm Maybe you want me to send you a floppy disk to analyse?
How many disks have you ?
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
Right now about 20 but I have access to more via friends.
Re: HxC @ LINN9000
DrJayWi wrote: Thu Dec 06, 2018 9:48 am Right now about 20 but I have access to more via friends.
I can do this job but this is definitively not free ;). send me an email to hxc2001 at hxc2001.com if you want.
DrJayWi
Re: HxC @ LINN9000
Post by DrJayWi »
Hi Jeff, thank you, but thats not what I meant. I mean to helo me and others with your software. There should be a reason you can do it but I cant.
Re: HxC @ LINN9000
then please post a picture of some your floppy disks, a screenshot of the hxc software reading a disk.
