S950 Format error
Re: S950 Format error
Hoolee wrote: Mon Feb 19, 2018 1:07 am yes, 3 totally different usb drives, all with the same result.
also, is there a mac guide similar to that? im running osx.
*Also, I've reformatted those drives more than once, each time with no luck*
this seems to be an hardware problem : even if the usb stick is not correctly formatted, it should bring you an error code, but it doesn't.
look likes the emulator doesn't see the usb sticks. did you got this device preflashed ?
Hoolee
Post by Hoolee »
yes, as i mentioned i bought it already with the gotek flash installed
Hoolee wrote: Mon Feb 19, 2018 9:25 am yes, as i mentioned i bought it already with the gotek flash installed
mhh. that's the problem with these "gotek". it can break easily since there is zero protection on its interfaces...
Hoolee
Post by Hoolee »
yes, this is a big headache, considering i dont know much about the flashing process, so troubleshooting becomes a mess.
Hoolee
Post by Hoolee »
*bump* I haven't resolved my issue yet. any ideaS? I really dont want to send it to a technician just so he can fix something that may not even be costly to fix.
Hoolee wrote: Tue Mar 13, 2018 1:41 am *bump* I haven't resolved my issue yet. any ideaS? I really dont want to send it to a technician just so he can fix something that may not even be costly to fix.
have you another gotek ?
Hoolee
Post by Hoolee »
by another gotek you mean another flashed drive? no, if that's what you're asking.
Bjarni
Post by Bjarni »
Ok i just wrote a post, im having similar problems with my gotek usb floppy emulator.
Im gonna try different usb stick or is it just broken?
Bjarni
Post by Bjarni »
I tried with 2gb skandisk, 4 gb kingston, and 8 gb
Showed something new with the 8gb started to load the update but then it just starts to blink 003
How big where your usb that you tried?
