I'm older than this S950 - can't quite get my head around...
Re: I'm older than this S950 - can't quite get my head aroun
HB3 wrote:The 1.6 mb files. EMXP could convert the to working FHE files but I couldn't get the HxC software to work.
Have you selected the "Predefined Disk Layout" to "Akai S950 3"5 HD Floppy" before loading the raw file ?
HB3
Post by HB3 »
Yes. I just went through the process to double check. I'm using the mac version of the software.
Here is an example Akai .img file:
https://we.tl/VMM5UOu7WO
Here is an example of the output from HXC:
https://we.tl/j7p6ejK58Y
HB3 wrote:Yes. I just went through the process to double check. I'm using the mac version of the software.
look fine.
Have you test the Akai images into this archive ? :
if doesn't work, have you the akai s950 resistor mod on your hxc ?
HB3
Post by HB3 »
My HxC had the S950 resistor mod added by Lotharek.
I have tested the image files in the Akai image archive and they work with my HxC.
When I convert a IMG file to a HEF file using EMXP they work with my HxC.
When I try to convert IMG files in the HxC software they DO NOT work with my HxC.
If you were able to get the example IMG file I uploaded to convert into a FHE file I must be doing something wrong. Please outline the exact steps you took to turn the IMG file into a FHE file. :?
HB3 wrote:My HxC had the S950 resistor mod added by Lotharek.
Is this HFE file working ? :
https://hxc2001.com/vrac/S1000-109.zip
If yes, convert the img file into this archive again, and send me back the hfe (and also try the hfe on the akai).
HB3
Post by HB3 »
Jeff wrote:Is this HFE file working ? :
Yes the HFE file is working on the Akai.
When I take the image file and convert I get this file:
https://we.tl/ykE8i8Qcyt
Both files (mine and your HFE) are exactly the same. So your file should work the same as mine...
HB3
Post by HB3 »
The software creates a file called "Raw Image"
When I rename that file and add .HFE at the end it doesn't work.
What am I doing wrong?
HB3 wrote:The software creates a file called "Raw Image"
i really don't know... both files are exactly the same.
Have you tried another sdcard ?
