SMC file support over 24Mbit Rom
kazmat
Post by kazmat »
I checked many files.
Dumped rom by my Griffin(firmware version V1) has not AA BB 02 in the header.
But, there are 2byte different. Byte 0Eh & 0Fh is 56 31 "V1" in ascii.
My griffin is early firmware. If I use later firmware, AA BB 02 header may be add.
But No problem I can change using binary editor.
Ok , I confirm drag&drop working AA BB 02 file. Thanks.
Please support GameDcotor series.
kazmat wrote:I checked many files.
ok :-)
kazmat
Post by kazmat »
I found some SMC files is not support drag & drop.
They are Super Pro Fighter and Super UFO format.
When I see ucon64 source(ufo.h & fig.h), they are slightly diffrent SMC format.
Please support these format if you can.
About SD version , can I use 20x4 character LCD in future ?
16x2 LCD is narrow.
kazmat wrote: About SD version , can I use 20x4 character LCD in future ?
16x2 LCD is narrow.
why not, but i will not support it (too expensive).
kazmat
Post by kazmat »
Hi Jeff
I am waiting GameDoctor support now.
Btw, I found my SD-card PCB can't write, delete file & format disk.
LCD freeze track 0.
Any advice about that ?
kazmat wrote:Hi Jeff
LCD freeze track 0.
If you use the latest firmware it's probably a bad decoupling and/or a bad 3V3 regulation and/or a bad pcb routing (no ground plane) problem.
kazmat
Post by kazmat »
ok I will check them later.
I have another question about FDD pinout of SDCard version.
This pinout is based on Amiga FDD pinout, I think.
In PC/AT pin34 is disk change signal but Ready signal in SDCard ver.
pin2 is density select signal but disk change signal in SDCard ver.
Should I need to change signal when I use as PC FDD ?
kazmat wrote:ok I will check them later.
no it's done by the software.
