Korg Trinity + Gotek with HxC problem
Re: Korg Trinity + Gotek with HxC problem
Would be nice to make a video of the issue. The description is confusing.
There is something to test into your email box.
Ramucho
Post by Ramucho »
A video of what ? The bugs I found ? Well, it doesn't need a video.
The facts : I've 4 disk images on the USB stick.
Now, if I press the up button for a long time and not release it, here is what's happenning on the digits :
000, 001, 002, 003, 000, 001, 002, 003, 000, 001, 000 then the sequence stops (3-times cycling)
Now if I press the down button for a long time and not release it, here is what's happenning on the digits :
003, 002, 001, 000 then the sequence stops (no cycling)
For the debouncing problem, you can see something like that on the digits everytime you press the button (up or down) once :
- up 000, (001), 002 or 001, (002), 003, there are glitches.
- down 003, (002), 001 or 002, (001), 000, there are glitches.
That's all :)
What about the most important problem I have with my Gotek ? Did you find something wrong in the signals chronology or state changes that not occurred in the disk changed protocol ?
Ramucho
Post by Ramucho »
Jeff wrote:There is something to test into your email box.
Great, I'll test that in the late afternoon and I'll keep you inform.
Many thanks :)
Ramucho
Post by Ramucho »
Many thanks :)
I've just updated the Gotek drive with the firmware you sent to me. Well, it's worse than before. The synth doesn't refresh the files. I can't see any filenames on the synth. So, impossible to load anything :(
I use IBM PC 1.44MB mode. I also tried some other possibilities but no success for the moment.
No luck.
I see that the synth fdc is NEC uPD72070GF, datasheet is here http://www.datasheetarchive.com/dl/Scan ... 101535.pdf
Try this : force the drive selection (the jumper) to the ground and retry.
Ramucho
Post by Ramucho »
Do you mean the DS1 jumper ? If so, it's already connected to ground.
Ramucho wrote:Do you mean the DS1 jumper ? If so, it's already connected to ground.
Not sure you understand me : Have you already permanently forced the drive selection with a wire between the vss/gnd and the selection signal (DS1, wire 12) ?
Ramucho
Post by Ramucho »
Yeap !!! I did it and great news ! It's better ! It works but there are still some troubles with the green LED that always stays lit. Also, I need to touch the screen of the synth twice to make the refresh happens. But now, I can change the disk images and the synth can refresh when I change the image number. Great improvement ! Thanx Jeff, U R the best !
Tested :
Loading -> OK
Writing -> OK
Deleting -> OK
Formatting -> Fail !!!
Just another thing, normally when I insert a floppy and change it to another one, the synth always indicates "Medium changed" and I must press "OK". Now, I don't see that anymore.
What I did is to remove the jumper (DS1) on the Gotek and connect a wire between GND and pin 12 of the Gotek connector.
Ramucho
Post by Ramucho »
To go further, I've tried something that made the synth react as it should do. I mean, it can now display the message "Medium changed".
What I did is to make a positive pulse on pin 12 :
1 - Select the image to load
2 - Remove the wire on pin 12 (high)
3 - Put it back again on pin 12 (low)
4 - Refresh the files by touching the screen
And that's all !!
Now, how to make that automatically ?
Ramucho wrote:To go further, I've tried something that made the synth react as it should do. I mean, it can now display the message "Medium changed".
And that's all !!
Which interface mode are you using ?
Can you try this : remove the usb stick, wait some second (4/5s) and reinsert it. is there a media change message ?
Btw can you try the previous version firmware (the current one available for everyone) ? It should work the same.
Ramucho
Post by Ramucho »
And that's all !!
I tried IBM PC 1.44MB then switched to auto and it was working the same (Shugart was working too). I'll try others this afternoon and original firmware too. I'll tell you :)
But, forcing the drive selection to 0 is not correct functionnaly speaking. :(
Try the usb stick ejection trick before.
Ramucho
Post by Ramucho »
Jeff wrote:Try the usb stick ejection trick before.
It works, well. No refresh problem :)
Now I'm trying with the original firmware...and, same behaviour as the modified firmware you sent to me.
Changing the mode doesn't change anything, everything runs the same way.
I retry to format. The fact is that it works, but it's very very very very long ! Saving too ! It's really slower than a real floppy. Oops !
Deleting and loading are quite normal.
Ramucho
Post by Ramucho »
@jeff, have a look here about how to detect a disk changed, maybe it helps :)
http://www.vcfed.org/forum/showthread.p ... ISK-CHANGE
https://www.msx.org/forum/msx-talk/hard ... -and-ready
Some chronograms and timings in this documentation :
http://info-coach.fr/atari/hardware/_fd ... 1de00a.pdf
