Spectrum TRD format soon?
Pryanick
Post by Pryanick »
Nothing happens when converting trd or scl files.
img2hfe tried to convert but...
img2hfe "f:" "f:" -HFE
converting file ZYNAPS!.SCL, 35611B
Loading f:\GaMEZ\Z\ZYNAPS!.SCL
no loader support the file f:\GaMEZ\Z\ZYNAPS!.SCL
Load error!: Image file not yet supported!
May be some driver is needed or img2hfe convertor version is wrong?
ZX-Spectrum/128k/TR-DOS/HxC Floppy Drive Emulator/YM2149F/ROM-DISK
Pryanick wrote:Nothing happens when converting trd or scl files.
maybe you don't have the right version or maybe there are a bug.
Please send me this SCL to this email:
Pryanick
Post by Pryanick »
Oh, yeah!
Now it works! :D
Tomorrow I'll try to buy all components.
What else MCU I can use?
Oh, I found one post in forum - pic18f4620 can be as a replacement with no schematic changes
Pryanick wrote:Oh, yeah!
Now it works! :D
yes PIC18F4525 and PIC18F4620 are ok.
DFL
Re: .TRD!
Post by DFL »
The new version is working perfectly in Spectrum and MSX, reading and writing, thanks.
About the SCL: I can see the files inside the images, but the computer hangs or resets after I try to run the demos. I believe this files are 128k images and I'm running a 48k Spectrum. Anyway, the SCL appears to be working...
Re: .TRD!
ok thanks for these tests :D .
Pryanick
Post by Pryanick »
I ordered pic18f4620, soon I will get it :D
...and Jeff, may be I can make some replacements for 74HCT14, 08 and 74LS01?
