Can I use 18F4620?
strange. Are you sure that your sdcard is in fat32 ? (look at the properties in windows).
Warning, your firmware version doesn’t support the sdcard exchange. So to change the sdcard, you need to switch off the emulator.
Can you try with an smaller sdcard (<512MB) ?
letigre
Post by letigre »
Yes, both are in FAT32.
I have one unit of 16Mb, but windows don´t let me do it. The only option for 16Mb is Fat16.
I´ll try to get a new smaller sdcard. Thanks
letigre wrote:Yes, both are in FAT32.
yes it seems that there are some bugs with bigger sdcard(>=512MB). 128MB cards are ok.
I will correct this as soon as possible.
letigre
Post by letigre »
Ok Jeff, I need to get another SD card.
How can I do to give FAT32 format? Does Windows let me do it?
letigre wrote:Ok Jeff, I need to get another SD card.
If your sdcard is <=32MB, Windows can't format it in FAT32.
can you dump and pack your 512MB and/or 1GB Sdcard and send me the zip ?
letigre
Post by letigre »
Hi Jeff, the link to download card image is:
http://rapidshare.com/files/144177057/SD_512Mb.rar.html
This should be better now :-) :
https://hxc2001.com/floppy_drive_emulat ... _PIC_c.zip
don't forget to compile it in release with all optimizations !
( menu Project->Build Options-> Project -> MPLAB C18 -> Categories -> Optimization)
letigre
Post by letigre »
Hi Jeff.... sorry, but don´t work :(
Now, I´m going to get a 128Mb SD !! :D
I hope test it now !! regards
letigre wrote:Hi Jeff.... sorry, but don´t work :(
this is not normal! what does the emulator ?
Can you remake an dump of your sdcard ? the last one was not an physical copy but a partition : it was 488MB and not 512MB !
letigre
Post by letigre »
yes, but I didn´t it.
The memory size is usually determined by Windows or another aplication like SDFormatter (I have both and happened the same).
letigre wrote:yes, but I didn´t it.
hmm, in fact i don't understand.
Did you try this new version with the 512MB or 1GB sdcard ?:
what says the floppy emulator when you insert the sdcard ?
letigre
Post by letigre »
Hi Jeff, good news !!! the emulator readind the SD card !! :D :D :D
I don´t know what happend, but I did a new compilation and now, it works.
I can select the wished file, after this I pressed the switch and then, the displays showed "TRACK 2".
I tryed to do a emulation on PC computer, but I can´t.
Do you have any text for explantion of jumper configuration and software settings??
Thanks !!!!!!
letigre wrote:Hi Jeff, good news !!! the emulator readind the SD card !! :D :D :D
Thanks !!!!!!
yes for PC you must put an jumper between pins 02 & 06 or 03 & 07 on J3 depending you want an "A:" or an "B:" drive.
J3 is mapped like this :
|FloppyConnector |
12 11 10 09
08 07 06 05
04 03 02 01
letigre
Post by letigre »
yeah !!!!!!! :D :D :D :D :D
it´s work !!!!!!
thank you very much for your cooperation, jeff
Best regards.
letigre
Post by letigre »
Hi Jeff.
Did you test the floppyemulator on Windows?
I have problems for reading it when the PC is runing under Windows operating system.
When the PC is initialited from standart floppy, it can read from the emulator, but is imposible when is initialited fron HD.... what is the problem? can you help to me? thanks
(I have Windows98 in my computer)
