HxC2001 in SF354 enclosure on 520ST - won't read the device
Re: HxC2001 in SF354 enclosure on 520ST - won't read the dev
blakespot wrote:Have we heard of other folks with this issue?
Jeff, it it possible that the device can't be used in this fashion? I have a Rev. F with latest firmware, again.
bp
Of course it can be used to emulate 2 drives...
The problem is related to the SF354. The DS1 signal is not connected to the HE10 34 connector on the SF354. DS1 signal go to the daisy chain output connector.
Your SF354 is the "Station A". You need to connect the drive "Drive Select B" wire to the wire n°12 of the floppy ribbon and set the ID0-A and ID1-B switch/jumper.
blakespot
Post by blakespot »
Thank you.
Of course, it worked.
bp
blakespot
Post by blakespot »
I will do a proper blog post with video on it shortly, but in a nutshell:
https://vine.co/v/O7bzDwBrTOt
bp
