How to make working .HFE disk images for EPS16+?
Re: How to make working .HFE disk images for EPS16+?
crc
Post by crc »
quickly testing out and seems to work. what did you do to make them work?
one thing tho. there where sample banks of drum machines there (tr-626 707 808 ect.) that are missing from this (20 files less). any chance you could convert those too, or tell me how to do it myself?
thank you alot!
Jeff wrote:This should be better now :
https://hxc2001.com/download/floppy_driv ... UT_HFE.zip
crc wrote:what did you do to make them work?
Just copy the efe to the root of the INPUT_EFE folder, nothing more...
crc wrote: there where sample banks of drum machines there (tr-626 707 808 ect.) that are missing from this (20 files less). any chance you could convert those too, or tell me how to do it myself?
16 files didn't pass. But i don't know why at all for the moment.
crc
Post by crc »
the .hfe images are still truning out empty when i try to do them. strangely the sound files i was looking for the most (the drum sounds) didn't convert.
crc wrote:the .hfe images are still truning out empty when i try to do them. strangely the sound files i was looking for the most (the drum sounds) didn't convert.
You should try to directly use EPSDISK.EXE to put these EFE on a true floppy to see if this is working.
teevee
Post by teevee »
Jeff wrote: Sun Mar 09, 2014 9:57 pm Have you tried this ? :
https://hxc2001.com/download/floppy_driv ... FE2HFE.zip
-----------H----H--X----X-----CCCCC----22222----0000-----0000------11----------
----------H----H----X-X-----C--------------2---0----0---0----0--1--1-----------
---------HHHHHH-----X------C----------22222---0----0---0----0-----1------------
--------H----H----X--X----C----------2-------0----0---0----0-----1-------------
-------H----H---X-----X---CCCCC-----222222----0000-----0000----1111------------
--------------------------------------------------------- https://hxc2001.com --
                          EPS EFE TO HFE Converter
                             Release 07/17/2013
Usage :
-> Put in the folder INPUT_EFE your EFE files.
-> Start convert_efe_to_hfe.bat
-> Get your HxC Floppy Emulator disk images (HFE) in the OUTPUT_HFE folder !
Note : OS Required Windows 98/Windows 2000/ XP / Vista (32bits) / Seven (32bits)
Would it be possible to make this in a Windows 64-bit version too?
teevee wrote: Thu May 30, 2019 7:15 pm Would it be possible to make this in a Windows 64-bit version too?
Not easily unfortunately ... epsdisk need to be redeveloped from scratch since no sources are available...
for the moment virtualbox or similar stuff are the only solutions...
teevee
Post by teevee »
Jeff wrote: Thu May 30, 2019 11:49 pm
I did not know this virtualbox, that could be a work-around :)
thanks for the tip.
mondo1976
Post by mondo1976 »
Tried the EFE2IMG program found here?
http://zine.r-massive.com/ensoniq-asr-eps-archive/
another_SD1
Post by another_SD1 »
Hi!
Did you tried this?
https://hxc2001.com/floppy/forum/viewtop ... =17&t=2008
It should work with Efe2HfeEps800.bat from this archive Ensoniq_EFE2HFEv2.zip mentioned in that post above.
