Request for HxC_SD_Bootloader_V1_0TOV1_1.upd
DoJu91
Re: Request for HxC_SD_Bootloader_V1_0TOV1_1.upd
Post by DoJu91 »
Jeff wrote:One question by curiosity : did you used the device in the past or was it in its package since 3 years ?
It's been in its packaging since I bought in June 2011, only just starting to use now I've got a test machine (Amiga 2000).
DoJu91
Post by DoJu91 »
Just managed to upgrade the firmware to HXCFE_V1_7_2_0.UPD after I tried on my second Amiga 2000
The SDcard access LED flashed in quick succession, then it bought up a choice of DF0
So just going through and testing a few HFE's
Don't forget this: Rev B = No write support on Amiga.
And with the next firmware (1.8.X.X) Rev B = No write support at all.
Duchemole
Post by Duchemole »
hi
i'd also need to update the bootloader on my old red HXC device (V.1.1.0), please ...
(i've never used it, it's my 1st HXC, never managed to make it work, then i've bought some REV C and they worked fine, i thought that red one was obsolete, but since it apparently could be updated ...)
thanks
Tronix
Post by Tronix »
I am also want update my very old HxC SD, so i need v1.2.0.0, or its bootloader ( HxC_SD_Bootloader_V1_0TOV1_1.upd) please...
Thank you!
