akai mpc 3000 problem with ejection virtual floppy
gianitaly
Re: akai mpc 3000 problem with ejection virtual floppy
Post by gianitaly »
Jeff wrote:@gianitaly & hizerock
New firmware in your email box :
Update it,
Set your switchs to ID0-A AND ID3-A.
Then on the emulator :
Remove the SDCard
Press select (middle button)
-> <Interface CFG >
-> <Custom>
-> <Pin 2 setting>
-> <nDensity>
-> <Pin 34 setting>
-> <nReady2> (the "2" is important ;) )
<Exit>
<Exit>
Let me know how the thing works.
hi jeff
with new firmware and partition 4.5 mb, menu settings, jumper id id-0a-3a not work
gianitaly
Post by gianitaly »
Update it,
Remove the SDCard
-> <Interface CFG >
-> <Custom>
-> <Pin 2 setting>
-> <nDensity>
-> <Pin 34 setting>
<Exit>
<Exit>
hi jeff
with firmware V1_8_2_0a and partition 4.5 work but it is necessary use the trick mpc error
for the moment the best option
gianitaly
Post by gianitaly »
I just sent to you an big 4.5MB disk image. Try to save something bigger than 1.44MB on this and tell me if this work.
(don't format the image !)
Anyway it seems that Akai choose once again a non-standard way to make the disk change detection :
Can you send me a picture of your original disk drive : I want to see the disk drive jumpers & brand + model !.
@hizerock : Please do the same.
hi jeff
I have sent the pictures of floppy drive in your mailbox
gianitaly wrote: hi jeff
Thanks for the pictures.
So the MPC3000 use the line 4 as a disk change signal. This explain the problem since the HxC doesn't drive this line.
Are you able to do simple modification ? (solder a wire ?)
The plan is to modify the hxc or the floppy cable in order to emulate this missing signal.
i think that the "Write Protect" signal should be ok to do the job.
gianitaly
Post by gianitaly »
hi jeff
yes ... I can solder a wire but I'm happy with how it works now
is a secure change?
What should I do?
hizerock
Post by hizerock »
@gianitaly are you able to save more than 1,44mb?
what are your settings?
thank you
gianitaly
Post by gianitaly »
hizerock wrote:@gianitaly are you able to save more than 1,44mb?
thank you
hxc software update installed: HXCFE_V1_8_2_0a.upd
That check your switch setting is Set to ID0-A.
Then on the emulator:
Remove the SDCard
-> <interface CFG>
-> <Custom>
-> <pin 2 Setting>
-> <nDensity>
-> <pin 34 Setting>
-> <nReady>
<exit>
<exit>
file 4.5 mb partition .hfe and HXCSDFE.CFG in the sd and go ....
send me your e-mail address for file
hizerock
Post by hizerock »
thank you
hizerock at(@) hotmail.fr
Are you able to save more than 1.44mb with this image?
gianitaly
Post by gianitaly »
hizerock wrote:thank you
yes the partitions is 4.5 mb
I have sent files..... check your email box
Let me know if this work in your mpc
hizerock
Post by hizerock »
Thank you I'll try tonight
hizerock
Post by hizerock »
It works in a strange way
the mpc only saves on one partition and the only way I found to save on other image is to turn off the mpc and power it on
but i can load sound from different partitions very strange isn't it?
gianitaly
Post by gianitaly »
hizerock wrote:It works in a strange way
hi
1 select beat1.hfe from your hxc floppy and save or load from mpc
2 at the end of the process remove sd
3 give the command load or saves with mpc and receive message:
error code FF80 there is no floppy disk in the drive.........
4 Push exit from the mpc screen menu
5 insert sd card, select for example beat2.hfe and save or load with mpc.........
6 enjoy beat archive!
hizerock
Post by hizerock »
I try this but the mpc still sees the first image I have saved on
hizerock
Post by hizerock »
@Jeff : can you tell me the mods to do on the reader?
Thank you
gianitaly
Post by gianitaly »
hizerock wrote:I try this but the mpc still sees the first image I have saved on
hi hizerock
we have the same sampler,the same operating system and the same hxc floppy emulator
work for me
must work even for you
try again
