HxC Floppy Emulator Software on Raspberry Pi
Re: HxC Floppy Emulator Software on Raspberry Pi
What do you need exactly ? The http GUI or the GUI working under X11 ?
korodit
Post by korodit »
Hi Jeff!!!
Both of them! :)
but, X11 Gui now working, I found description for Linux whezzy.....
Now my prolem the FTDI2xx..... I do everything from ftdi install guide, but not working.
I try FTDI 1.1.12 on Acer laptop (os: Debian Whezzy, i386)..... and working fine, but on raspberry PI Modell B, fresh Raspbian os, FTDI2xx driver-raspberry ver. not working. example read software not working......
I got this error:
./read: error while loading shared libraries: libftd2xx.so: cannot open shared object file: No such file or directory
Have You got any Idea????
Thank You!!!!!!!
korodit
Post by korodit »
HI Jeff!!!!
Now I found ftdi2xx.so.1.1.12 working file from Your`s forum! :)
When I start HXCfloppyemulator, go to USB-HXC button, then say FDTI 2xx driver not loaded.
What I do it wrong ??????
Please Help, this very important for me.
Thank You
Try to run it as root : sudo ...
korodit
Post by korodit »
Hi Jeff!
I try sudo! , but not working..... :(
Linux hxcfloppyemulator (1307) use Ftdi2xx or Libftdi ????
korodit wrote:Hi Jeff!
Libftdi.
korodit
Post by korodit »
Hi JeFF!
Now I compiled LibFTdi from intra2net.com. The Compile succes, but Raspberry PI and hxcfe, hxcfefloppyemulator not working.
In hxcfe I'v got this error:
sudo ./hxcfe -usb:
libhxcfe version : 2.8.8.1
Starting usb emulation -
Starting CPLDFloppyEmulator Hw manager...
Loading ftd2xx.dll...
Error while loading FTDI library! Missing entry point ?
Stopping HxCFloppyEmulator...
and in hxcfloppyemulator (GUI)
Status:FTDI D2xx Driver not installed!
Maybe can You send me sdcard image to raspberry????? Please Jeff Help Me!!!!
or Can You tell Me, What I do wrong??????
and don't forget the browser solution :oops:
Thank You!
korodit wrote: Loading ftd2xx.dll...
Have you this file ? :
/usr/local/lib/libftd2xx.so
Which version are you using ?
korodit
Post by korodit »
Hi Jeff!
Yes I have
This version try:
1., I try ftdi2xx.so.1.1.12 from http://www.ftdichip.com
2., I try ftdi2xx.so from your forum post
3., I try libftdi1.2 from http://www.intra2net.com/
Thnk's
Tamas
korodit
Post by korodit »
Hi Jeff!
Now It's WORKING!!!!! :mrgreen:
solution is:
sudo apt-get install libftdi-dev
Thank's
and I'd like some info about html - web interface controll. :roll:
Beaglz
Post by Beaglz »
Hi Folks,
I am in need of your help to get the HXC running via Rasp Pi as a universal floppy emulator (as per the video at the start of this thread). I get a bit lost when it comes to setting up Rasp Pi (compiling) hence the request for help - I have searched for any guides and instructions but they all seem to be aimed at people who know what they are doing which isn't me.
I have managed to flash my USB Gotek with HxC and got the correct messages so that is a good start.
Now I need to get the software compiled for the Rasp Pi - is anyone able to provide step by step instructions or send me an image that I can transfer to the SD-Card? I am wanting to include the GUI and from what I can figure out will also need the USB driver?
Greatly appreciate your help or if you can direct me to a location that will solve the above for me.
Cheers,
Beaglz.
mariareese
Post by mariareese »
info helping for me at some points .. thanku .. :)
